이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Faulty Wi-Fi or Bluetooth connection? Replace the AirPort/Bluetooth cable.
필요한 것
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
Carefully peel the AirPort/Bluetooth ribbon cable from its channel within the rear speaker assembly.
다른 10명이 해당 안내서를 완성하였습니다.
