Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove two 11 mm Phillips screws securing the hard drive bracket to the upper case.
Remove the 3.1 mm Phillips screw securing the hard drive cable to the upper case.
거의 끝나갑니다!
결론
다른 15명이 해당 안내서를 완성하였습니다.
