주요 콘텐츠로 건너뛰기
MacBook Unibody Model A1342 Hard Drive Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MacBook Unibody Model A1342 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Remove two 11 mm Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive in the hard drive bracket.
  2. MacBook Unibody Model A1342 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Lift the retaining bracket out of the upper case.
    • When putting the bracket back after replacing the drive, it is easy to put in backwards. If it doesn't seat smoothly, then reverse it and try again.
  3. MacBook Unibody Model A1342 Hard Drive Replacement: 3 단계, 이미지 1/3 MacBook Unibody Model A1342 Hard Drive Replacement: 3 단계, 이미지 2/3 MacBook Unibody Model A1342 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Lift the hard drive by its pull tab and pull it away from the upper case, minding the cable still attaching it to the logic board.
    • In some revisions of the MacBook A1342, the hard drive bracket may include two rubber brackets (as highlighted in the second picture.) The correct orientation of the rubber brackets is shown in the third picture.
  4. MacBook Unibody Model A1342 Hard Drive Replacement: 4 단계, 이미지 1/2 MacBook Unibody Model A1342 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Remove the hard drive cable by pulling its connector straight away from the hard drive.
결론
Walter Galan
694,692 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 995
