주요 콘텐츠로 건너뛰기
MacBook Unibody Model A1342 Lower Case Replacement
필요한 것
  1. MacBook Unibody Model A1342 Lower Case Replacement, Lower Case: 1 단계, 이미지 1/1
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Lower Case Replacement: 2 단계, 이미지 1/3 MacBook Unibody Model A1342 Lower Case Replacement: 2 단계, 이미지 2/3 MacBook Unibody Model A1342 Lower Case Replacement: 2 단계, 이미지 3/3
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
결론
다른 74명이 해당 안내서를 완성하였습니다.
Walter Galan
686,655 평판
안내서 1,203개 작성하였습니다
2 댓글
Apple has a recall on this part, so you can get a replacement for an improved version free and save yourself $149.99. Check out http://www.apple.com/support/macbook-bot...
Shane - 답글
Would the Macbook Pro back cover also fit this?
wow - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 17
30일 전: 61
전체 시간: 69,047
