주요 콘텐츠로 건너뛰기
MacBook Unibody Model A1342 MagSafe Board Replacement
필요한 것
  1. MacBook Unibody Model A1342 MagSafe Board Replacement, Lower Case: 1 단계, 이미지 1/1
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 MagSafe Board Replacement: 2 단계, 이미지 1/3 MacBook Unibody Model A1342 MagSafe Board Replacement: 2 단계, 이미지 2/3 MacBook Unibody Model A1342 MagSafe Board Replacement: 2 단계, 이미지 3/3
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
  3. MacBook Unibody Model A1342 MagSafe Board Replacement, Battery: 3 단계, 이미지 1/1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    • It may be easier to use your fingernails to lift up on both sides of the connector.
  4. MacBook Unibody Model A1342 MagSafe Board Replacement, Rear Vent: 4 단계, 이미지 1/1
    • Remove the following screws from the optical drive side of the rear vent:
    • Two 10 mm T8 Torx
    • Two 5.2 mm Phillips
  5. MacBook Unibody Model A1342 MagSafe Board Replacement: 5 단계, 이미지 1/1
    • Remove the following screws from the port side of rear vent:
    • Two 10 mm T8 Torx
  6. MacBook Unibody Model A1342 MagSafe Board Replacement: 6 단계, 이미지 1/1
    • Carefully lift the rear vent out of the upper case.
  7. MacBook Unibody Model A1342 MagSafe Board Replacement, Logic Board: 7 단계, 이미지 1/1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable up off the logic board.
  8. MacBook Unibody Model A1342 MagSafe Board Replacement: 8 단계, 이미지 1/3 MacBook Unibody Model A1342 MagSafe Board Replacement: 8 단계, 이미지 2/3 MacBook Unibody Model A1342 MagSafe Board Replacement: 8 단계, 이미지 3/3
    • Use a spudger to pry the fan connector straight up and out of its socket on the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  9. MacBook Unibody Model A1342 MagSafe Board Replacement: 9 단계, 이미지 1/2 MacBook Unibody Model A1342 MagSafe Board Replacement: 9 단계, 이미지 2/2
    • Remove the following three screws securing the fan to the upper case:
    • One 7.1 mm Phillips screw.
    • Two 5 mm Phillips screws.
    • Lift the fan out of the upper case.
  10. MacBook Unibody Model A1342 MagSafe Board Replacement: 10 단계, 이미지 1/1
    • Carefully pry the delicate rear speaker connector up off the logic board. These small L/R speaker connectors are quite easily broken.
    • Use extreme caution; this connector is easily destroyed.
  11. MacBook Unibody Model A1342 MagSafe Board Replacement: 11 단계, 이미지 1/1
    • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
  12. MacBook Unibody Model A1342 MagSafe Board Replacement: 12 단계, 이미지 1/2 MacBook Unibody Model A1342 MagSafe Board Replacement: 12 단계, 이미지 2/2
    • Use a spudger to pry the right speaker connector and sleep LED connector up off the logic board.
    • These connectors are very delicate and easily broken.
  13. MacBook Unibody Model A1342 MagSafe Board Replacement: 13 단계, 이미지 1/1
    • Use the flat end of a spudger to pry the trackpad ribbon cable connector up off the logic board.
  14. MacBook Unibody Model A1342 MagSafe Board Replacement: 14 단계, 이미지 1/2 MacBook Unibody Model A1342 MagSafe Board Replacement: 14 단계, 이미지 2/2
    • Use your fingernail to flip up the locking flap on the ZIF socket for the keyboard ribbon cable.
    • Use the tip of a spudger to slide the keyboard ribbon cable out of its socket.
  15. MacBook Unibody Model A1342 MagSafe Board Replacement: 15 단계, 이미지 1/1
    • Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
  16. MacBook Unibody Model A1342 MagSafe Board Replacement: 16 단계, 이미지 1/2 MacBook Unibody Model A1342 MagSafe Board Replacement: 16 단계, 이미지 2/2
    • Use a spudger to pry the left speaker connector and microphone connector up off the logic board.
  17. MacBook Unibody Model A1342 MagSafe Board Replacement: 17 단계, 이미지 1/2 MacBook Unibody Model A1342 MagSafe Board Replacement: 17 단계, 이미지 2/2
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
  18. MacBook Unibody Model A1342 MagSafe Board Replacement: 18 단계, 이미지 1/2 MacBook Unibody Model A1342 MagSafe Board Replacement: 18 단계, 이미지 2/2
    • Gently pull the display data cable connector away from its socket on the logic board.
    • Pull the socket parallel to the face of the logic board.
    • The display data cable socket is made of very thin metal and is easily bent. Be sure to pull the connector straight away from its socket.
  19. MacBook Unibody Model A1342 MagSafe Board Replacement: 19 단계, 이미지 1/1
    • Remove the six 4.1 to 4.4 mm T6 Torx screws securing the logic board to the upper case.
    • Remove the two 4.1 to 4.5 mm T6 Torx screws securing the MagSafe board to the upper case.
    • On some models, these screws may be T7. Be careful not to strip away the head with a smaller bit.
  20. MacBook Unibody Model A1342 MagSafe Board Replacement: 20 단계, 이미지 1/3 MacBook Unibody Model A1342 MagSafe Board Replacement: 20 단계, 이미지 2/3 MacBook Unibody Model A1342 MagSafe Board Replacement: 20 단계, 이미지 3/3
    • Lift the side of the logic board opposite the ports out of the upper case.
    • Rotate the logic board away from the upper case until the ports clear the lip molded in the upper case.
    • Pull the logic board and MagSafe board away from the edge of the upper case as one piece.
    • The MagSafe board may get accidentally disconnected during this process. As a precaution, be sure the MagSafe board connector is securely seated in its socket before lowering the logic board back into the upper case.
    • Before lowering the logic board back into the upper case, be sure the left speaker and microphone cables are seated in their channels cut into the upper case (as seen in the third picture).
  21. MacBook Unibody Model A1342 MagSafe Board Replacement, MagSafe Board: 21 단계, 이미지 1/1
    • Pull the MagSafe board connector away from its socket on the logic board.
    • Pull the connector parallel to the face of the logic board.
결론
다른 181명이 해당 안내서를 완성하였습니다.
Walter Galan
696,442 평판
안내서 1,203개 작성하였습니다
댓글 22개
Excellent guide, very easy to follow, success!!!!
khoover - 답글
I did it Success! Thank you very much!!!!
I had some problems after I reassemble all the parts, first the Macbook wasn't turn on, but I wait few seconds and it's turn on again. Second the key A on the keyboard not worked but I take off the ribbon cable of keyboard and put it on again and the keyboard worked normally.
This is my comment I hope that help someone.
rodrigoj6 - 답글
Another excellent guide. Can be tedious. Good, bright lighting a must, and patience.
svenaustx - 답글
The computer fell on the MagSafe cable, wich pressed in the MagSafe board (socket) into the body so the cable and the socket couldn't reach contact. From this guide I only did steps 1 to 6 and 17 to 19(only the two screws for the MagSafe board). Then I could move the MagCharger board out enough so it could make contact with the charger cable. Then I tightened the two screws again. Allthou I was as carefull I could with the display data cable (step 17 -18) and looked on youtube allso, it did break a bit at the surrounding solder joint. But it's working. I didn't have to replace the MagCharger board, just move it back into position.
Andreas - 답글
Hi I have a problem with the fan connector. I accidentally break the plastic fan socket off the logic board.. I am worried as the way am looking at it its difficult to solder it back as it too tiny.. What should I do?
Nielven Araullo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 18
30일 전: 77
전체 시간: 120,004
