주요 콘텐츠로 건너뛰기
MacBook Unibody Model A1342 Optical Drive Replacement
단지 전제 조건
이 안내서는 다른 안내서의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MacBook Unibody Model A1342 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1개 중 1개
    • Remove the single 12 mm Phillips screw securing the top of the rear speaker housing to the upper case.
  2. MacBook Unibody Model A1342 Optical Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
    • This screw is located in a gap within the right speaker assembly, and is visible only from the hinge edge.
  3. MacBook Unibody Model A1342 Optical Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up off the logic board.
  4. MacBook Unibody Model A1342 Optical Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the rear speaker connector up off the logic board.
    • Pry up underneath the wires.
    • This connector is very delicate and easily broken.
  5. MacBook Unibody Model A1342 Optical Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully rotate the rear speaker assembly (with AirPort/Antenna cables still attached) out of the lower case.
  6. MacBook Unibody Model A1342 Optical Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
  7. MacBook Unibody Model A1342 Optical Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the single 4.5 mm Phillips screw securing the optical drive bracket to the upper case near the fan.
  8. MacBook Unibody Model A1342 Optical Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the two 2.5 mm Phillips screws securing the optical drive to the upper case near the optical drive opening.
  9. MacBook Unibody Model A1342 Optical Drive Replacement: 9 단계, 이미지 1개 중 1개
    • Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Walter Galan
701,042 평판
안내서 1,203개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 820
