주요 콘텐츠로 건너뛰기
MacBook Unibody Model A1342 Rear Speaker Assembly Replacement
단지 전제 조건
이 안내서는 다른 안내서의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement, Rear Speaker Assembly: 1 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
  2. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the following screws securing the right speaker assembly to the upper case:
    • One 12 mm Phillips screw.
    • One 3 mm Phillips screw.
  3. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
  4. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: 4 단계, 이미지 2개 중 1개 MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Pry the AirPort and Bluetooth antenna connectors (3 total) up off the AirPort/Bluetooth card.
    • De-route the long antenna from its channel in the rear speaker housing.
  5. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the rear speaker cable connector up off the logic board.
  6. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the rear speaker assembly from the upper case.
  7. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: 7 단계, 이미지 2개 중 1개 MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully peel the AirPort/Bluetooth cable from its channel within the rear speaker assembly.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable up off the rear speaker.
  8. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: 8 단계, 이미지 1개 중 1개
    • Remove three 3 mm Phillips screws securing the AirPort/Bluetooth board to the rear speaker assembly.
  9. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: 9 단계, 이미지 1개 중 1개
    • Lift the AirPort/Bluetooth board up off the rear speaker assembly.
결론
작성자
3다른 기여자 명과 함께
Walter Galan
701,042 평판
안내서 1,203개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 1
전체 시간: 708
