소개
Use this guide to remove the cast aluminum rear vent from your MacBook.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove the following screws from the optical drive side of the rear vent:
Two 10 mm T8 Torx
Two 5.2 mm Phillips
거의 끝나갑니다!
결론
다른 10명이 해당 안내서를 완성하였습니다.
