주요 콘텐츠로 건너뛰기
MacBook Unibody Model A1342 Rear Vent Replacement
필요한 것
  1. MacBook Unibody Model A1342 Rear Vent Replacement, Lower Case: 1 단계, 이미지 1/1
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Rear Vent Replacement: 2 단계, 이미지 1/3 MacBook Unibody Model A1342 Rear Vent Replacement: 2 단계, 이미지 2/3 MacBook Unibody Model A1342 Rear Vent Replacement: 2 단계, 이미지 3/3
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
  3. MacBook Unibody Model A1342 Rear Vent Replacement, Battery: 3 단계, 이미지 1/1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    • It may be easier to use your fingernails to lift up on both sides of the connector.
  4. MacBook Unibody Model A1342 Rear Vent Replacement, Rear Vent: 4 단계, 이미지 1/1
    • Remove the following screws from the optical drive side of the rear vent:
    • Two 10 mm T8 Torx
    • Two 5.2 mm Phillips
  5. MacBook Unibody Model A1342 Rear Vent Replacement: 5 단계, 이미지 1/1
    • Remove the following screws from the port side of rear vent:
    • Two 10 mm T8 Torx
  6. MacBook Unibody Model A1342 Rear Vent Replacement: 6 단계, 이미지 1/1
    • Carefully lift the rear vent out of the upper case.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Walter Galan
686,574 평판
안내서 1,203개 작성하였습니다
댓글 한 개
Wow.....i fix it my speaker problem
NAVEEN Justin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 11,501
