주요 콘텐츠로 건너뛰기
Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement
필요한 것
  1. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement, Outer Casing: 1 단계, 이미지 1/1
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: 2 단계, 이미지 1/1
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: 3 단계, 이미지 1/1
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement, Sync Component: 4 단계, 이미지 1/1
    • Remove the two black 5 mm screws (circled in red) from the back of the power button component using a size J1 philips head screwdriver. You can identify this by the code J5-B on the component.
    • Lift the small, rectangular circuit board out and set it aside.
  5. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: 5 단계, 이미지 1/1
    • Locate the sync component hardware. It is a small circuit board that sits sideways with respect to the other circuit boards around it.
    • Remove the two 5mm black screws (circled in red) holding the circuit board in place using a size J1 philips head screwdriver. The component should now slide out vertically.
  6. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: 6 단계, 이미지 1/1
    • Follow the wires connected to the sync component back to the main circuit board. Unplug the component from the main circuit board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Hollynn Ricker
회원 가입일: 09/28/16
451 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-1, Cagle Fall 2016 USF Tampa, Team 1-1, Cagle Fall 2016 회원
USFT-CAGLE-F16S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
How do I replace the sync wire? Where can I purchase a new sync component?
Ange - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 38
전체 시간: 2,259
