주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement
필요한 것
    1. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement, Outer Casing: 1 단계, 이미지 1개 중 1개
      • Flip the guitar over so it is back side up. The battery compartment should be facing up.
      • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
      • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
      댓글 쓰기
    2. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: 2 단계, 이미지 1개 중 1개
      • Turn the device over so the front of the guitar is facing you.
      • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
      댓글 쓰기
    3. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: 3 단계, 이미지 1개 중 1개
      • Gently lift the white panel and twist 90 degrees clockwise.
      • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
      댓글 쓰기
    1. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement, Sync Component: 4 단계, 이미지 1개 중 1개
      • Remove the two black 5 mm screws (circled in red) from the back of the power button component using a size J1 philips head screwdriver. You can identify this by the code J5-B on the component.
      • Lift the small, rectangular circuit board out and set it aside.
      댓글 쓰기
    2. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: 5 단계, 이미지 1개 중 1개
      • Locate the sync component hardware. It is a small circuit board that sits sideways with respect to the other circuit boards around it.
      • Remove the two 5mm black screws (circled in red) holding the circuit board in place using a size J1 philips head screwdriver. The component should now slide out vertically.
      댓글 쓰기
    3. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: 6 단계, 이미지 1개 중 1개
      • Follow the wires connected to the sync component back to the main circuit board. Unplug the component from the main circuit board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hollynn Ricker
회원 가입일: 09/28/16
451 평판
안내서 2개를 작성함
USF Tampa, Team 1-1, Cagle Fall 2016 USF Tampa, Team 1-1, Cagle Fall 2016 회원
USFT-CAGLE-F16S1G1
4 회원들
안내서 72개를 작성함
1가이드 댓글
How do I replace the sync wire? Where can I purchase a new sync component?
Ange - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 29
지난 30일: 56
전체 시간: 3,010
