주요 콘텐츠로 건너뛰기
Magellan RoadMate 1440 Antenna Replacement
필요한 것
  1. Magellan RoadMate 1440 Antenna Replacement, Magellan RoadMate 1440 Back Cover Disassembly: 1 단계, 이미지 1/1
    • Place the GPS with the screen facing down.
  2. Magellan RoadMate 1440 Antenna Replacement: 2 단계, 이미지 1/2 Magellan RoadMate 1440 Antenna Replacement: 2 단계, 이미지 2/2
    • Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
  3. Magellan RoadMate 1440 Antenna Replacement: 3 단계, 이미지 1/2 Magellan RoadMate 1440 Antenna Replacement: 3 단계, 이미지 2/2
    • Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
  4. Magellan RoadMate 1440 Antenna Replacement: 4 단계, 이미지 1/3 Magellan RoadMate 1440 Antenna Replacement: 4 단계, 이미지 2/3 Magellan RoadMate 1440 Antenna Replacement: 4 단계, 이미지 3/3
    • Insert the black spudger into the crease in the side of the GPS.
    • Move the end of the spudger down to break the seal between the two plastic shells.
    • Continue doing this along each side of the GPS to ensure a smooth removal.
  5. Magellan RoadMate 1440 Antenna Replacement: 5 단계, 이미지 1/3 Magellan RoadMate 1440 Antenna Replacement: 5 단계, 이미지 2/3 Magellan RoadMate 1440 Antenna Replacement: 5 단계, 이미지 3/3
    • Fully separate the two sides of the case.
    • Remove the tape on the battery wires and the tape on the speaker wires.
  6. Magellan RoadMate 1440 Antenna Replacement, Battery: 6 단계, 이미지 1/2 Magellan RoadMate 1440 Antenna Replacement, Battery: 6 단계, 이미지 2/2
    • Use the black spudger to break the seal between the adhesive and battery. Use the same spudger to continue to pry the battery from the backing
    • This may be a little tough to separate the battery and the adhesive
  7. Magellan RoadMate 1440 Antenna Replacement: 7 단계, 이미지 1/2 Magellan RoadMate 1440 Antenna Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Lift the battery from the device
    • Once the battery is free from the adhesive, remove the piece of tape with a pair of tweezers that is covering the connection of the battery to the motherboard.
  8. Magellan RoadMate 1440 Antenna Replacement: 8 단계, 이미지 1/2 Magellan RoadMate 1440 Antenna Replacement: 8 단계, 이미지 2/2
    • Unplug the battery from the mother board by pulling back the clips and pulling the wires away from the motherboards receptacle
    • It is important for your and the device's safety to remove the battery before continuing with any other part removals.
    • It is not necessary to separate the red and white wires from the battery. A replacement battery pack will come with similar wires already attached.
  9. Magellan RoadMate 1440 Antenna Replacement, Antenna: 9 단계, 이미지 1/3 Magellan RoadMate 1440 Antenna Replacement, Antenna: 9 단계, 이미지 2/3 Magellan RoadMate 1440 Antenna Replacement, Antenna: 9 단계, 이미지 3/3
    • Identify the antenna.
    • Locate the two screws in the antenna.
    • Use a Phillips #0 screwdriver to remove the two 2.5mm Phillips #0 screws.
  10. Magellan RoadMate 1440 Antenna Replacement: 10 단계, 이미지 1/1
    • After the screws have been removed, move the motherboard so that it is sitting in the side with the speaker and battery.
    • Using a soldering iron, melt the solder connecting the antenna to the motherboard. For instructions on how to use the soldering iron, refer to Soldering Technique Guide for instructions.
    • The soldering iron will be hot. Handle it with caution.
결론
Benton Burns
회원 가입일: 03/21/16
209 평판
안내서 2개 작성하였습니다
Clemson, Team 7-3, Benson Spring 2016 Clemson, Team 7-3, Benson Spring 2016 회원
CLEM-BENSON-S16S7G3
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 214
