소개
This guide will illustrate how to replace the device's antenna.
필요한 것
Use the black spudger to break the seal between the adhesive and battery. Use the same spudger to continue to pry the battery from the backing
Identify the antenna.
Locate the two screws in the antenna.
Use a Phillips #0 screwdriver to remove the two 2.5mm Phillips #0 screws.
After the screws have been removed, move the motherboard so that it is sitting in the side with the speaker and battery.
Using a soldering iron, melt the solder connecting the antenna to the motherboard. For instructions on how to use the soldering iron, refer to Soldering Technique Guide for instructions.
