주요 콘텐츠로 건너뛰기
Magellan RoadMate 5236T-LM Speaker Replacement
필요한 것
  1. Magellan RoadMate 5236T-LM Speaker Replacement, Back Cover: 1 단계, 이미지 1/3 Magellan RoadMate 5236T-LM Speaker Replacement, Back Cover: 1 단계, 이미지 2/3 Magellan RoadMate 5236T-LM Speaker Replacement, Back Cover: 1 단계, 이미지 3/3
    • Place the device face down on a flat surface.
    • Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
  2. Magellan RoadMate 5236T-LM Speaker Replacement: 2 단계, 이미지 1/3 Magellan RoadMate 5236T-LM Speaker Replacement: 2 단계, 이미지 2/3 Magellan RoadMate 5236T-LM Speaker Replacement: 2 단계, 이미지 3/3
    • Gently wedge a plastic opening tool into the seam along the side of the device.
    • Slide the tool along the seam to pry apart the front and back covers.
  3. Magellan RoadMate 5236T-LM Speaker Replacement: 3 단계, 이미지 1/2 Magellan RoadMate 5236T-LM Speaker Replacement: 3 단계, 이미지 2/2
    • A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
    • Use tweezers to disconnect the ZIF connector from the motherboard.
    • The ZIF connector may disconnect itself from the motherboard when removing the tape.
  4. Magellan RoadMate 5236T-LM Speaker Replacement, Speaker: 4 단계, 이미지 1/2 Magellan RoadMate 5236T-LM Speaker Replacement, Speaker: 4 단계, 이미지 2/2
    • Lay the back panel on a flat surface with the battery, motherboard, and speaker facing up.
    • Use a plastic opening tool to gently pull the battery away from the back panel in order to remove the adhesive that helps the battery stick to the panel.
  5. Magellan RoadMate 5236T-LM Speaker Replacement: 5 단계, 이미지 1/1
    • Unscrew the two 5mm screws using a Phillips #000 screwdriver.
  6. Magellan RoadMate 5236T-LM Speaker Replacement: 6 단계, 이미지 1/3 Magellan RoadMate 5236T-LM Speaker Replacement: 6 단계, 이미지 2/3 Magellan RoadMate 5236T-LM Speaker Replacement: 6 단계, 이미지 3/3
    • Use a Phillips #000 screwdriver to remove three 5mm screws that hold the motherboard down to the the back panel.
    • Remove the battery, speaker and motherboard. Place them on a flat surface upside down.
  7. Magellan RoadMate 5236T-LM Speaker Replacement: 7 단계, 이미지 1/1
결론
Felix Muwanguzi
회원 가입일: 10/24/16
355 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-7, Catania Fall 2016 UMass Dartmouth, Team 4-7, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G7
3 회원들
안내서 5개 작성하였습니다
One Comment
Where can I find a replacement speaker?
Tom Phillips - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 138
