주요 콘텐츠로 건너뛰기
Marshall MS-2 Speaker Replacement
필요한 것
  1. Marshall MS-2 Speaker Replacement, Disassembling Marshall MS-2 Micro Amp Case Disassembly: 1 단계, 이미지 1/1
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
    To turn the device off, turn the rightmost knob counterclockwise, not the leftmost one (which controls the volume).
    Célestin Taramarcaz - 답글
  2. Marshall MS-2 Speaker Replacement: 2 단계, 이미지 1/3 Marshall MS-2 Speaker Replacement: 2 단계, 이미지 2/3 Marshall MS-2 Speaker Replacement: 2 단계, 이미지 3/3
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Marshall MS-2 Speaker Replacement: 3 단계, 이미지 1/2 Marshall MS-2 Speaker Replacement: 3 단계, 이미지 2/2
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Marshall MS-2 Speaker Replacement: 4 단계, 이미지 1/1
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
  5. Marshall MS-2 Speaker Replacement, Speaker: 5 단계, 이미지 1/1
  6. Marshall MS-2 Speaker Replacement: 6 단계, 이미지 1/2 Marshall MS-2 Speaker Replacement: 6 단계, 이미지 2/2
    • Remove the two 7/16" screws located in the bottom left and top right corners with a phillips head screw driver. After removing the screws, the metal clips will need to be removed as well.
  7. Marshall MS-2 Speaker Replacement: 7 단계, 이미지 1/1
    • You may now remove the speaker by pulling it straight out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
MacKinley
회원 가입일: 10/22/13
811 평판
안내서 5개 작성하였습니다
University of Maryland, Team 1-1, Shastany Fall 2013 University of Maryland, Team 1-1, Shastany Fall 2013 회원
UMD-SHASTANY-F13S1G1
3 회원들
안내서 5개 작성하였습니다
댓글 4개
So where do we find a replacement speaker? If no parts are required what is the point in taking the speaker out?
Patrick Gillett - 답글
This speaker unavailable in Marlins. Any online sources. How should an untutored amateur repairer describe the replacement in order to get the right thing
Any speaker that will fit should work. Might want to check to make sure the Watts they consume are the same. I imagine that if you put a speaker in that consumes more Watts you could potentially over heat the power supply or other components.
MacKinley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 27
전체 시간: 4,224
