주요 콘텐츠로 건너뛰기
Martian Victory LED Screen Replacement
필요한 것
  1. Martian Victory LED Screen Replacement, Back Plate: 1 단계, 이미지 1/2 Martian Victory LED Screen Replacement, Back Plate: 1 단계, 이미지 2/2
    • Unscrew the four 3.4 mm flat head screws
  2. Martian Victory LED Screen Replacement: 2 단계, 이미지 1/1
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Martian Victory LED Screen Replacement, Lithium Battery: 3 단계, 이미지 1/1
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Martian Victory LED Screen Replacement: 4 단계, 이미지 1/1
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Martian Victory LED Screen Replacement, LED Screen: 5 단계, 이미지 1/1
    • Locate the ribbon connection, and use remove the clips holding the strip on each side using needle tool.
  6. Martian Victory LED Screen Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • With a pair of tweezers, carefully remove the ribbon strip connection.
  7. Martian Victory LED Screen Replacement: 7 단계, 이미지 1/1
    • Remove the screw driver holding the LED screen and Speaker in place.
  8. Martian Victory LED Screen Replacement: 8 단계, 이미지 1/1
    • Insert a small flat screw driver under the speaker in order to remove it.
  9. Martian Victory LED Screen Replacement: 9 단계, 이미지 1/2 Martian Victory LED Screen Replacement: 9 단계, 이미지 2/2
    • Using tweezers, remove the speaker and move off to the side.
  10. Martian Victory LED Screen Replacement: 10 단계, 이미지 1/2 Martian Victory LED Screen Replacement: 10 단계, 이미지 2/2
    • Place a small flat head screwdriver under the LED screen, and carefully push it out of it's socket.
  11. Martian Victory LED Screen Replacement: 11 단계, 이미지 1/1
    • Remove final connection to accelerometer. The LED screen is now separated from the device.
결론
Robert Sanchez
회원 가입일: 10/31/16
201 평판
안내서 2개 작성하였습니다
IUPUI, Team 3-3, Baechle Fall 2016 IUPUI, Team 3-3, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S3G3
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 219
