주요 콘텐츠로 건너뛰기
Martian Victory Motherboard Replacement
필요한 것
  1. Martian Victory Motherboard  Replacement, Back Plate: 1 단계, 이미지 1/2 Martian Victory Motherboard  Replacement, Back Plate: 1 단계, 이미지 2/2
    • Unscrew the four 3.4 mm flat head screws
  2. Martian Victory Motherboard  Replacement: 2 단계, 이미지 1/1
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Martian Victory Motherboard  Replacement, Lithium Battery: 3 단계, 이미지 1/1
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Martian Victory Motherboard  Replacement: 4 단계, 이미지 1/1
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Martian Victory Motherboard  Replacement, Motherboard: 5 단계, 이미지 1/1
    • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
  6. Martian Victory Motherboard  Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
  7. Martian Victory Motherboard  Replacement: 7 단계, 이미지 1/1
    • Use PH00 screwdriver to remove 5.2mm Phillips head screw
  8. Martian Victory Motherboard  Replacement: 8 단계, 이미지 1/3 Martian Victory Motherboard  Replacement: 8 단계, 이미지 2/3 Martian Victory Motherboard  Replacement: 8 단계, 이미지 3/3
    • Use ESD safe tweezers to remove the gold ribbon cable.
    • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
  9. Martian Victory Motherboard  Replacement: 9 단계, 이미지 1/2 Martian Victory Motherboard  Replacement: 9 단계, 이미지 2/2
    • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
    • You can now access the parts and pieces on the bottom of, and below the motherboard.
결론
Dominic Coffey
회원 가입일: 10/24/16
243 평판
안내서 2개 작성하였습니다
IUPUI, Team 3-3, Baechle Fall 2016 IUPUI, Team 3-3, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S3G3
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 217
