주요 콘텐츠로 건너뛰기
Master and Dynamic MW50 Battery Replacement
필요한 것
  1. Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: 1 단계, 이미지 3개 중 1개 Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: 1 단계, 이미지 3개 중 2개 Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: 1 단계, 이미지 3개 중 3개
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Battery Replacement, Battery: 4 단계, 이미지 2개 중 1개 Master and Dynamic MW50 Battery Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Remove the tape attaching the thicker white wire to the battery. You may consider keeping the tape to reattach the wire later.
  5. Master and Dynamic MW50 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Desolder the two wires circled here.
  6. Master and Dynamic MW50 Battery Replacement: 6 단계, 이미지 2개 중 1개 Master and Dynamic MW50 Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Use an iFixit opening tool or something similar to pry out the battery.
    • There are two small tabs circled here that are holding the battery in. Push these down while prying to make the battery come out easier.
결론
작성자
4다른 기여자 명과 함께
Tyler Guffey
회원 가입일: 01/24/19
208 평판
안내서 2개를 작성함
Cal Poly, Team S1-G4, White Winter 2019 Cal Poly, Team S1-G4, White Winter 2019 회원
CPSU-WHITE-W19S1G4
4 회원들
안내서 12개를 작성함
2가이드 댓글
Hi, do you know where it’s possible to buy replacement batteries??
Mike - 답글
Did you ever find out what spec of battery and where to buy? Really want to run my MW50s wirelessly again.
TP 75 -
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 32
전체 시간: 2,348
