주요 콘텐츠로 건너뛰기
Master and Dynamic MW50 Charging Port Replacement
필요한 것
  1. Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: 1 단계, 이미지 3개 중 1개 Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: 1 단계, 이미지 3개 중 2개 Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: 1 단계, 이미지 3개 중 3개
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Charging Port Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Charging Port Replacement: 3 단계, 이미지 1개 중 1개
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Charging Port Replacement, Charging Port: 4 단계, 이미지 2개 중 1개 Master and Dynamic MW50 Charging Port Replacement, Charging Port: 4 단계, 이미지 2개 중 2개
    • Remove the two 2mm screws pictured with a JIS #00 screwdriver.
    • Gently pull the silver cover off of the ear piece.
  5. Master and Dynamic MW50 Charging Port Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the two 2mm screws shown with a JIS #00 screwdriver.
  6. Master and Dynamic MW50 Charging Port Replacement: 6 단계, 이미지 1개 중 1개
    • Lift up the mother board with the attached charging port to see the soldering points. You must desolder these points in order to detach (and re-attach) the charging port.
결론
작성자
4다른 기여자 명과 함께
Tyler Guffey
회원 가입일: 01/24/19
208 평판
안내서 2개를 작성함
Cal Poly, Team S1-G4, White Winter 2019 Cal Poly, Team S1-G4, White Winter 2019 회원
CPSU-WHITE-W19S1G4
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 17
전체 시간: 472
