주요 콘텐츠로 건너뛰기
Master and Dynamic MW50 Right/Left Speaker Replacement
필요한 것
  1. Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: 1 단계, 이미지 1/3 Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: 1 단계, 이미지 2/3 Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: 1 단계, 이미지 3/3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Right/Left Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Right/Left Speaker Replacement: 3 단계, 이미지 1/1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Right/Left Speaker Replacement, Right/Left Speaker: 4 단계, 이미지 1/1
    • Desolder the two wires connected to the speaker.
  5. Master and Dynamic MW50 Right/Left Speaker Replacement: 5 단계, 이미지 1/1
    • Use a heating gun to remove the glue from the speaker.
    • Once the glue is removed, gently pull out the speaker.
결론
Katie Dunnigan
회원 가입일: 01/24/19
85 평판
안내서 1개 작성함
Cal Poly, Team S1-G4, White Winter 2019 Cal Poly, Team S1-G4, White Winter 2019 회원
CPSU-WHITE-W19S1G4
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
This is awesome but Master & Dynamic don’t sell replacement 45mm 32 ohm drivers and won’t share the specs.
If anyone know where to get a replacement which will work well with these headphones please share!!!
paul
bloodygoose@icloud.com
psullivan_au - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 667
