주요 콘텐츠로 건너뛰기
Master and Dynamic MW50 Wireless Connector Replacement
필요한 것
  1. Master and Dynamic MW50 Wireless Connector Replacement, Master and Dynamic MW50 Disassembly: 1 단계, 이미지 3개 중 1개 Master and Dynamic MW50 Wireless Connector Replacement, Master and Dynamic MW50 Disassembly: 1 단계, 이미지 3개 중 2개 Master and Dynamic MW50 Wireless Connector Replacement, Master and Dynamic MW50 Disassembly: 1 단계, 이미지 3개 중 3개
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Wireless Connector Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Wireless Connector Replacement: 3 단계, 이미지 1개 중 1개
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Wireless Connector Replacement, Wireless Connector: 4 단계, 이미지 3개 중 1개 Master and Dynamic MW50 Wireless Connector Replacement, Wireless Connector: 4 단계, 이미지 3개 중 2개 Master and Dynamic MW50 Wireless Connector Replacement, Wireless Connector: 4 단계, 이미지 3개 중 3개
    • Remove the 2mm screw holding the side cover plate in place with a JIS #00 screwdriver.
    • Move the side cover off to the side.
    • The black cable connected to the motherboard from the side cover can be gently pulled off from the motherboard side. It isn't soldered on.
  5. Master and Dynamic MW50 Wireless Connector Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the black tape holding the connector in place.
  6. Master and Dynamic MW50 Wireless Connector Replacement: 6 단계, 이미지 1개 중 1개
    • Desolder the connector from the motherboard.
    • Refer to this picture for soldering the connector back to the motherboard.
  7. Master and Dynamic MW50 Wireless Connector Replacement: 7 단계, 이미지 1개 중 1개
    • Solder the new Bluetooth connector into place.
결론
작성자
3다른 기여자 명과 함께
Neil Patel
회원 가입일: 01/24/19
162 평판
안내서 1개를 작성함
Cal Poly, Team S1-G4, White Winter 2019 Cal Poly, Team S1-G4, White Winter 2019 회원
CPSU-WHITE-W19S1G4
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 10
전체 시간: 377
