주요 콘텐츠로 건너뛰기
Memorex CD Alarm Clock Radio Antenna Replacement
필요한 것
  1. Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: 1 단계, 이미지 1/3 Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: 1 단계, 이미지 2/3 Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: 1 단계, 이미지 3/3
    • Turn the clock radio over so the bottom is facing up.
    • Pull the tab upward and remove the cover from the battery compartment.
    • Remove the batteries.
  2. Memorex CD Alarm Clock Radio Antenna Replacement: 2 단계, 이미지 1/3 Memorex CD Alarm Clock Radio Antenna Replacement: 2 단계, 이미지 2/3 Memorex CD Alarm Clock Radio Antenna Replacement: 2 단계, 이미지 3/3
    • Remove the five screws on the bottom of the device with a screwdriver.
    • Grasp the top and bottom and gently pull apart.
  3. Memorex CD Alarm Clock Radio Antenna Replacement, Antenna: 3 단계, 이미지 1/1
    • Locate the small silver transistor between the front left speaker and the tuning knob. The antenna should be attached directly below the transistor.
    • Deolder the antenna wire from the circuit board, and remove the wire.
결론
Aubrey Frank
회원 가입일: 02/15/18
399 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 800
