주요 콘텐츠로 건너뛰기
Merch Source Projector Entertainment II Cooling Fan Replacement
필요한 것
  1. Merch Source Projector Entertainment II Cooling Fan Replacement, Outer Casing: 1 단계, 이미지 2개 중 1개 Merch Source Projector Entertainment II Cooling Fan Replacement, Outer Casing: 1 단계, 이미지 2개 중 2개
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
  2. Merch Source Projector Entertainment II Cooling Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
  3. Merch Source Projector Entertainment II Cooling Fan Replacement: 3 단계, 이미지 2개 중 1개 Merch Source Projector Entertainment II Cooling Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Using your hands, gently pry the top and bottom of the projector casing apart.
  4. Merch Source Projector Entertainment II Cooling Fan Replacement, Cooling Fan: 4 단계, 이미지 2개 중 1개 Merch Source Projector Entertainment II Cooling Fan Replacement, Cooling Fan: 4 단계, 이미지 2개 중 2개
    • Locate the 80 mm fan and slide upward straight out of the housing.
  5. Merch Source Projector Entertainment II Cooling Fan Replacement: 5 단계, 이미지 2개 중 1개 Merch Source Projector Entertainment II Cooling Fan Replacement: 5 단계, 이미지 2개 중 2개
    • Unsolder the red and black connections off of the motherboard.
    • If there are zip ties around the cables, they will need to be cut to remove the fan.
    • Need some help? Follow this guide to learn soldering basics.
    • While soldering the metal connections will get very hot. Never touch the iron with your hand.
    • Make sure that the projector is fully turned off and not plugged in. Allow up to 30 minutes for projector to cool down.
    • If there is hot glue within the connection in on the motherboard, you will need to peel it off simply using your fingers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Stephanie
회원 가입일: 01/08/15
282 평판
안내서 3개를 작성함
Cal Poly, Team 18-3, Maness Winter 2015 Cal Poly, Team 18-3, Maness Winter 2015 회원
CPSU-MANESS-W15S18G3
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 41
전체 시간: 2,568
