주요 콘텐츠로 건너뛰기
Meta Quest 2 Fan Assembly Replacement
필요한 것
  1. Meta Quest 2 Fan Assembly Replacement, Power off your Meta Quest 2: 1 단계, 이미지 1개 중 1개
    • Hold the power button for three seconds to fully turn off your headset.
    • You'll hear a power down chime, and the LED next to the power button will turn off.
  2. Meta Quest 2 Fan Assembly Replacement, Remove the facial interface: 2 단계, 이미지 2개 중 1개 Meta Quest 2 Fan Assembly Replacement, Remove the facial interface: 2 단계, 이미지 2개 중 2개
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
  3. Meta Quest 2 Fan Assembly Replacement: 3 단계, 이미지 2개 중 1개 Meta Quest 2 Fan Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
  4. Meta Quest 2 Fan Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
  5. Meta Quest 2 Fan Assembly Replacement, Unclip the side straps: 5 단계, 이미지 3개 중 1개 Meta Quest 2 Fan Assembly Replacement, Unclip the side straps: 5 단계, 이미지 3개 중 2개 Meta Quest 2 Fan Assembly Replacement, Unclip the side straps: 5 단계, 이미지 3개 중 3개
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
  6. Meta Quest 2 Fan Assembly Replacement: 6 단계, 이미지 2개 중 1개 Meta Quest 2 Fan Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
  7. Meta Quest 2 Fan Assembly Replacement, Remove the top strap: 7 단계, 이미지 2개 중 1개 Meta Quest 2 Fan Assembly Replacement, Remove the top strap: 7 단계, 이미지 2개 중 2개
    • Separate the hook and loop strip on the top strap.
  8. Meta Quest 2 Fan Assembly Replacement, Remove the head strap: 8 단계, 이미지 2개 중 1개 Meta Quest 2 Fan Assembly Replacement, Remove the head strap: 8 단계, 이미지 2개 중 2개
    • Unthread the top strap from its bracket.
    • Remove the head strap.
  9. Meta Quest 2 Fan Assembly Replacement, Remove the eyepiece trim screws: 9 단계, 이미지 2개 중 1개 Meta Quest 2 Fan Assembly Replacement, Remove the eyepiece trim screws: 9 단계, 이미지 2개 중 2개
    • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
  10. Meta Quest 2 Fan Assembly Replacement, Release the eyepiece trim clips: 10 단계, 이미지 2개 중 1개 Meta Quest 2 Fan Assembly Replacement, Release the eyepiece trim clips: 10 단계, 이미지 2개 중 2개
    • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
  11. Meta Quest 2 Fan Assembly Replacement: 11 단계, 이미지 3개 중 1개 Meta Quest 2 Fan Assembly Replacement: 11 단계, 이미지 3개 중 2개 Meta Quest 2 Fan Assembly Replacement: 11 단계, 이미지 3개 중 3개
    • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
    • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
    • Leave the opening pick in the seam to prevent the clips from reengaging.
  12. Meta Quest 2 Fan Assembly Replacement: 12 단계, 이미지 3개 중 1개 Meta Quest 2 Fan Assembly Replacement: 12 단계, 이미지 3개 중 2개 Meta Quest 2 Fan Assembly Replacement: 12 단계, 이미지 3개 중 3개
    • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
    • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
  13. Meta Quest 2 Fan Assembly Replacement, Reposition the eyepiece trim: 13 단계, 이미지 3개 중 1개 Meta Quest 2 Fan Assembly Replacement, Reposition the eyepiece trim: 13 단계, 이미지 3개 중 2개 Meta Quest 2 Fan Assembly Replacement, Reposition the eyepiece trim: 13 단계, 이미지 3개 중 3개
    • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
    • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
    • Set the trim down on your work surface, making sure not to strain the cable.
  14. Meta Quest 2 Fan Assembly Replacement, Disconnect the face sensor: 14 단계, 이미지 3개 중 1개 Meta Quest 2 Fan Assembly Replacement, Disconnect the face sensor: 14 단계, 이미지 3개 중 2개 Meta Quest 2 Fan Assembly Replacement, Disconnect the face sensor: 14 단계, 이미지 3개 중 3개
    • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
  15. Meta Quest 2 Fan Assembly Replacement: 15 단계, 이미지 2개 중 1개 Meta Quest 2 Fan Assembly Replacement: 15 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to pull the face sensor cable out of the ZIF connector.
  16. Meta Quest 2 Fan Assembly Replacement, Remove the eyepiece trim: 16 단계, 이미지 1개 중 1개
    • Remove the eyepiece trim.
  17. Meta Quest 2 Fan Assembly Replacement, Reassembly note: 17 단계, 이미지 2개 중 1개 Meta Quest 2 Fan Assembly Replacement, Reassembly note: 17 단계, 이미지 2개 중 2개
    • During reassembly:
    • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
    • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
  18. Meta Quest 2 Fan Assembly Replacement, Reassembly note: 18 단계, 이미지 3개 중 1개 Meta Quest 2 Fan Assembly Replacement, Reassembly note: 18 단계, 이미지 3개 중 2개 Meta Quest 2 Fan Assembly Replacement, Reassembly note: 18 단계, 이미지 3개 중 3개
    • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
    • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
    • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
    • Use a spudger to press the lock tab down towards the cable to lock it in place.
  19. Meta Quest 2 Fan Assembly Replacement, Remove the front cover screws: 19 단계, 이미지 3개 중 1개 Meta Quest 2 Fan Assembly Replacement, Remove the front cover screws: 19 단계, 이미지 3개 중 2개 Meta Quest 2 Fan Assembly Replacement, Remove the front cover screws: 19 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
    • One recessed in the top-left corner
    • One recessed in the top-right corner
    • Three along the lower edge
  20. Meta Quest 2 Fan Assembly Replacement, Release the front cover clips: 20 단계, 이미지 2개 중 1개 Meta Quest 2 Fan Assembly Replacement, Release the front cover clips: 20 단계, 이미지 2개 중 2개
    • The front cover is still held in place by clips along the bottom and side edges.
    • Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
    • Pry with the opening pick to release the front cover clips.
  21. Meta Quest 2 Fan Assembly Replacement: 21 단계, 이미지 3개 중 1개 Meta Quest 2 Fan Assembly Replacement: 21 단계, 이미지 3개 중 2개 Meta Quest 2 Fan Assembly Replacement: 21 단계, 이미지 3개 중 3개
    • Slide the opening clip along the seam and pry to release all the clips securing the front cover.
  22. Meta Quest 2 Fan Assembly Replacement, Remove the front cover: 22 단계, 이미지 1개 중 1개
    • Remove the front cover.
  23. Meta Quest 2 Fan Assembly Replacement, Disconnect the top right antenna: 23 단계, 이미지 3개 중 1개 Meta Quest 2 Fan Assembly Replacement, Disconnect the top right antenna: 23 단계, 이미지 3개 중 2개 Meta Quest 2 Fan Assembly Replacement, Disconnect the top right antenna: 23 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
    • Lift the antenna connector straight up to disconnect it.
    • Guide the antenna cable out of its metal clip holding it in place.
  24. Meta Quest 2 Fan Assembly Replacement, Remove the battery cable bracket: 24 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
    • One 4.4 mm‑long screw
    • Two 2.3 mm‑long screws
  25. Meta Quest 2 Fan Assembly Replacement: 25 단계, 이미지 3개 중 1개 Meta Quest 2 Fan Assembly Replacement: 25 단계, 이미지 3개 중 2개 Meta Quest 2 Fan Assembly Replacement: 25 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to grasp the battery cable bracket.
    • Twist the cable bracket slightly so that its bottom left corner unclips from the motherboard.
    • Remove the battery cable bracket.
  26. Meta Quest 2 Fan Assembly Replacement, Disconnect the battery: 26 단계, 이미지 2개 중 1개 Meta Quest 2 Fan Assembly Replacement, Disconnect the battery: 26 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the battery press connector from the motherboard.
    • The battery press connector can disconnect accidentally during reassembly. Check this connector before you attach the bracket.
  27. Meta Quest 2 Fan Assembly Replacement, Disconnect the antenna: 27 단계, 이미지 3개 중 1개 Meta Quest 2 Fan Assembly Replacement, Disconnect the antenna: 27 단계, 이미지 3개 중 2개 Meta Quest 2 Fan Assembly Replacement, Disconnect the antenna: 27 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Insert one arm of a pair of tweezers under the metal neck of the black antenna cable near the fan assembly.
  28. Meta Quest 2 Fan Assembly Replacement, Loosen the front antenna assembly: 28 단계, 이미지 2개 중 1개 Meta Quest 2 Fan Assembly Replacement, Loosen the front antenna assembly: 28 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the eight screws securing the antenna assembly to the headset:
    • Four 4.4 mm‑long screws
    • Two 4.8 mm‑long screws
    • Two 10.7 mm‑long screws
  29. Meta Quest 2 Fan Assembly Replacement: 29 단계, 이미지 2개 중 1개 Meta Quest 2 Fan Assembly Replacement: 29 단계, 이미지 2개 중 2개
    • Use your fingers to flip up the antenna assembly enough to access the cable underneath it.
  30. Meta Quest 2 Fan Assembly Replacement: 30 단계, 이미지 2개 중 1개 Meta Quest 2 Fan Assembly Replacement: 30 단계, 이미지 2개 중 2개
    • Use tweezers to unclip the antenna cable from its metal clip.
  31. Meta Quest 2 Fan Assembly Replacement, Remove the front antenna assembly: 31 단계, 이미지 1개 중 1개
    • Remove the front antenna assembly.
  32. Meta Quest 2 Fan Assembly Replacement, Disconnect the fan: 32 단계, 이미지 2개 중 1개 Meta Quest 2 Fan Assembly Replacement, Disconnect the fan: 32 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to grab the fan connector and carefully slide it out of its socket.
  33. Meta Quest 2 Fan Assembly Replacement, Loosen the LED flex cable: 33 단계, 이미지 2개 중 1개 Meta Quest 2 Fan Assembly Replacement, Loosen the LED flex cable: 33 단계, 이미지 2개 중 2개
    • Use the point of an opening pick to loosen the adhesive securing the LED flex cable from the top of the fan assembly.
  34. Meta Quest 2 Fan Assembly Replacement, Remove the fan assembly: 34 단계, 이미지 1개 중 1개
    • Remove the two screws securing the fan assembly to the headset:
    • One 4.4 mm‑long Phillips screw
    • One 3.6 mm‑long Torx T2 screw
  35. Meta Quest 2 Fan Assembly Replacement: 35 단계, 이미지 3개 중 1개 Meta Quest 2 Fan Assembly Replacement: 35 단계, 이미지 3개 중 2개 Meta Quest 2 Fan Assembly Replacement: 35 단계, 이미지 3개 중 3개
    • Lift the fan assembly and remove it.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
313,818 평판
안내서 729개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,781개를 작성함
2가이드 댓글
Amazing guide!! I would never have tried to replace the internal fan without this concise walkthrough. The photos of each step and half-step of the process were extremely helpful. The extra tidbits on the trouble areas helped prevent some serious headache.
Standup job!
For.The.Tech.Of.It - 답글
Great guide but I didn't need to replace the fan in the end - a screw had worked loose and lodged in the fan. Cheap fix 🙂
MisterPriscilla - 답글
댓글 쓰기
조회 통계:
지난 24시간: 18
지난 7일: 105
지난 30일: 391
전체 시간: 5,595
