주요 콘텐츠로 건너뛰기
MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement
필요한 것
  1. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Determine the unloader assembly: 1 단계, 이미지 1/3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Determine the unloader assembly: 1 단계, 이미지 2/3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Determine the unloader assembly: 1 단계, 이미지 3/3
    • There are two versions of the unloader assembly:
    • First image—earlier pressure washers feature an all-in-one assembly (part 8-0631) that’s easy to replace, but gave users the ability to break the pump.
    • Second image—later models use a tamper-proof, harder to remove unloader (part 8-0656), connected by a series of pipe fittings.
    • This guide is written for the tamper-proof unloader assembly.
    • If you need to remove an all-in-one style unloader, use a large adjustable wrench to unscrew the two large Banjo bolts. This will disconnect the unloader from the pump assembly.
  2. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement: 2 단계, 이미지 1/2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement: 2 단계, 이미지 2/2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  3. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the hose clamp: 3 단계, 이미지 1/2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the hose clamp: 3 단계, 이미지 2/2
    • Use a 1/4" socket or a large flathead screwdriver to loosen the hose clamp near the inlet filter.
    • Slide the hose clamp away from the end of the hose.
  4. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Disconnect the return hose: 4 단계, 이미지 1/2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Disconnect the return hose: 4 단계, 이미지 2/2
    • Wiggle the hose and pull it off of the brass nipple.
  5. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Position the support block: 5 단계, 이미지 1/1
    • Slide a 3" tall block underneath the pump assembly to help support the pump.
  6. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Re-position the return elbow: 6 단계, 이미지 1/2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Re-position the return elbow: 6 단계, 이미지 2/2
    • Use a 1/2" or adjustable wrench to loosen and twist the return elbow half a turn, so that it faces the opposite direction.
    • This will allow the fitting to clear the pump edge without being removed.
  7. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the filter: 7 단계, 이미지 1/2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the filter: 7 단계, 이미지 2/2
    • Use a large adjustable wrench to loosen and unscrew the filter.
  8. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Remove the filter: 8 단계, 이미지 1/1
    • Remove the filter with the return elbow attached.
  9. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the input elbow: 9 단계, 이미지 1/2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the input elbow: 9 단계, 이미지 2/2
    • Use a 1" or large adjustable wrench to loosen and unscrew the pump input elbow.
  10. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Remove the input elbow: 10 단계, 이미지 1/1
    • Remove the input elbow fitting.
  11. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the output assembly: 11 단계, 이미지 1/2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the output assembly: 11 단계, 이미지 2/2
    • Use a 3/4" or adjustable wrench to loosen and disconnect the coupling from the pump assembly.
  12. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Remove the output assembly: 12 단계, 이미지 1/1
    • Remove the output assembly.
  13. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Clamp the output assembly: 13 단계, 이미지 1/1
    • You will need to remove the remaining fittings from the output assembly in order to replace the unloader.
    • Secure the output assembly in a large vise.
  14. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the output elbow: 14 단계, 이미지 1/3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the output elbow: 14 단계, 이미지 2/3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the output elbow: 14 단계, 이미지 3/3
    • Hold the outlet fitting in place with a 15/16" or large adjustable wrench.
    • Use a 3/4" or adjustable wrench to loosen and unscrew the output elbow from the outlet fitting.
  15. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement: 15 단계, 이미지 1/1
    • Remove the output elbow with the quick-connect socket attached to it.
  16. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the coupling nipple: 16 단계, 이미지 1/2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the coupling nipple: 16 단계, 이미지 2/2
    • Use a 3/4" or adjustable wrench to loosen and unscrew the coupling nipple from the unloader.
  17. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Remove the coupling nipple: 17 단계, 이미지 1/1
    • Remove the coupling nipple.
  18. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the return hose nipple: 18 단계, 이미지 1/2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the return hose nipple: 18 단계, 이미지 2/2
    • Use a 11/16" or adjustable wrench to loosen and unscrew the return hose nipple from the unloader.
    • You do not need to disconnect the hose from the nipple.
  19. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Remove the return hose: 19 단계, 이미지 1/1
    • Remove the return hose nipple with the hose attached.
  20. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Check for plug placement: 20 단계, 이미지 1/3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Check for plug placement: 20 단계, 이미지 2/3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Check for plug placement: 20 단계, 이미지 3/3
    • Only the unloader assembly remains.
    • Compare the original unloader with the replacement part. The replacement part may have a plug installed in the wrong port.
    • Use an 8 mm (5/16" OK) hex key to remove and re-install the plug into the correct port.
결론
When you re-connect the fittings, clean off the old thread sealant and apply new thread sealant (tape or pipe dope).
다른 4명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
258,910 평판
안내서 531개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,077개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 37
전체 시간: 1,163
