소개
Replacing the screen on the Surface 3 is really the only good reason to go about replacing anything in it. You will likely end up breaking the screen and needing to replace it with any of the other replacement guides. This guide may help you to identify how to take it off without breaking it (a major accomplishment).
필요한 것
Warm up an iOpener following the instructions found in the iOpener guide.
Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
Locate the point where the display is still attached to the motherboard.
Use a flat spudger to pry off the RF shielding/bracket retainer.
Use a thin guitar pick to release the snap pin from the display to the motherboard.
다른 35명이 해당 안내서를 완성하였습니다.
댓글 15개
They sell them on this website
is the adhesive that is needed available on this site?
What would happen if that little RF shielding part was not reinstalled?
meric robb - 답글
The RF shield both helps prevent the closely packed together components from interfering with each other and also holds in the ZIF connector latch (the little black piece that I warn you not to lose) for the display cable. The results could vary between screen flickering with inconsistent touchscreen performance and the display cable possibly coming lose inside the device and needing to open it up and reattach it. I didn't find it too difficult to bend the RF shield back on, but you may have a harder or easier time.
