주요 콘텐츠로 건너뛰기
Microsoft Surface 3 Speaker Replacement
필요한 것
  1. Microsoft Surface 3 Speaker Replacement, Casing: 1 단계, 이미지 2개 중 1개 Microsoft Surface 3 Speaker Replacement, Casing: 1 단계, 이미지 2개 중 2개
    • Warm up an iOpener following the instructions found in the iOpener guide.
    • Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
  2. Microsoft Surface 3 Speaker Replacement: 2 단계, 이미지 2개 중 1개 Microsoft Surface 3 Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
    • This may take significant force. A fingernail might work better for the initial lift
    • If you push straight down near the edge you will go through the speaker mesh and possibly end up damaging your speaker; try to push the pick in at a shallow angle.
  3. Microsoft Surface 3 Speaker Replacement: 3 단계, 이미지 2개 중 1개 Microsoft Surface 3 Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
    • If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
    • While the glass on this display is not particularly sharp when broken, it is still broken glass and you should be careful with it.
  4. Microsoft Surface 3 Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Flip the display over so that parts underneath it are easily accessible.
    • Do not pull out the display as it is still attached to the motherboard.
    • If you are replacing the display, or want it out of the way, continue with the display replacement guide steps.
  5. Microsoft Surface 3 Speaker Replacement, Speaker: 5 단계, 이미지 1개 중 1개
    • You will be working in these areas of the Surface 3 in order to replace the speakers.
  6. Microsoft Surface 3 Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • Use a pick to get under the speaker part and undo the adhesive that keeps it attached to the back casing.
  7. Microsoft Surface 3 Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Use the pick to gently lift on the red and black wire in order to dislodge the connection between the speaker wire and the motherboard.
  8. Microsoft Surface 3 Speaker Replacement: 8 단계, 이미지 2개 중 1개 Microsoft Surface 3 Speaker Replacement: 8 단계, 이미지 2개 중 2개
    • Repeat the same steps for the second speaker.
  9. Microsoft Surface 3 Speaker Replacement: 9 단계, 이미지 1개 중 1개
    • Simply replace the old speakers by snapping the new speakers into place and connecting the red and black wire to the motherboard.
결론
작성자
3다른 기여자 명과 함께
Andy Stone
회원 가입일: 10/08/15
284 평판
안내서 2개를 작성함
Cal Poly, Team 5-12, Maness Fall 2015 Cal Poly, Team 5-12, Maness Fall 2015 회원
CPSU-MANESS-F15S5G12
4 회원들
안내서 22개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 23
전체 시간: 3,749
