주요 콘텐츠로 건너뛰기
Microsoft Surface Headphones Motherboard Replacement
필요한 것
  1. Microsoft Surface Headphones Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Microsoft Surface Headphones Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Firmly grasp the ear cushions and rotate them counterclockwise, about 45 degrees, until you hear a "click."
    • To replace the motherboard, you only need to remove the right cushion, labeled with an "R" on the headband.
  2. Microsoft Surface Headphones Motherboard Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the three 2.6 mm screws securing the right speaker housing to the chassis.
  3. Microsoft Surface Headphones Motherboard Replacement: 3 단계, 이미지 1/1
    • Lift the speaker housing away from the chassis, taking care not to damage the motherboard connections.
    • Desolder the two speaker motherboard connections.
    • Desoldering and soldering are delicate procedures, and there is a potential for device damage.
  4. Microsoft Surface Headphones Motherboard Replacement: 4 단계, 이미지 1/1
    • Desolder the red and black speaker connections.
  5. Microsoft Surface Headphones Motherboard Replacement: 5 단계, 이미지 1/1
    • Desolder the 23 connections from the motherboard.
    • Before soldering the connections to your new motherboard, be sure to pay close attention to which wire goes where; they're very easy to mix up.
  6. Microsoft Surface Headphones Motherboard Replacement: 6 단계, 이미지 1/1
    • Use a Torx screwdriver to remove the four screws.
    • Lift the motherboard up and out of the chassis.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Ethan Haight
회원 가입일: 02/08/22
843 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 28
전체 시간: 1,043
