소개
Use this guide to replace the battery pack in the Microsoft Surface Pro.
필요한 것
Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
Using a T3 Torx screwdriver, remove a total of 23 screws from the screen bezel of the Surface Pro.
다른 31명이 해당 안내서를 완성하였습니다.
24 댓글
Thank you for that awesome guide!
Do you know where can i buy a battery for surface pro 2??
Thanks
I am also trying to find out where to acquire the Surface Pro batteries...???
im also looking for a surface pro replacement battery.
I just bought one for $70 at a site called newpower99.com... should be here in 2 days. I have no idea if it will work, but it says it comes with a toolkit to replace it. I hope it works.
Matt -
