이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
Apply a suction cup as close as possible to the edge of the display.
Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
Starting from the top edge, lift the display slightly. If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
Before completely removing the display, disconnect the three display cables.
Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro.
Use the T5 torx screw driver to unscrew the 6 T5 screws in the left and right outside metal panels
Use the T2 torx screw driver to unscrew the 23 T2 screws on the left and right outside metal panels
Unscrew the two T5 torx screws located on each side of the charging port.
Once you have unscrewed the charging port, you can gently pull it out with your hands.
다른 5명이 해당 안내서를 완성하였습니다.
