주요 콘텐츠로 건너뛰기
Microsoft Surface Pro Display Replacement
필요한 것
  1. Microsoft Surface Pro Display Replacement, Heat edges of display: 1 단계, 이미지 1개 중 1개
    • Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
    • If you're using an iOpener it may take several cycles of reheating and applying it to soften the adhesive enough. Every time, let the iOpener sit on the display for at least a minute before reheating to allow the adhesive to soften.
  2. Microsoft Surface Pro Display Replacement, Lift display and cut adhesive: 2 단계, 이미지 3개 중 1개 Microsoft Surface Pro Display Replacement, Lift display and cut adhesive: 2 단계, 이미지 3개 중 2개 Microsoft Surface Pro Display Replacement, Lift display and cut adhesive: 2 단계, 이미지 3개 중 3개
    • Apply a suction cup as close as possible to the edge of the display.
    • Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
    • Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
    • Do not insert the opening pick past the bezel of the display—you may permanently damage the display.
    • The bezel is much thinner on the bottom of the display, which is the side with the Windows logo. To avoid damage, don't poke too deep with the opening pick on the bottom edge.
    • Ribbon cables and a circuit board are approx. 0.6 cm from the edge of the glass.
    • Be very careful and move slowly during this step. The display is fragile and will crack if too much force is applied against it. If your tools seem stuck, apply more heat to further soften the adhesive.
  3. Microsoft Surface Pro Display Replacement, Disconnect/peel off ribbon cables: 3 단계, 이미지 3개 중 1개 Microsoft Surface Pro Display Replacement, Disconnect/peel off ribbon cables: 3 단계, 이미지 3개 중 2개 Microsoft Surface Pro Display Replacement, Disconnect/peel off ribbon cables: 3 단계, 이미지 3개 중 3개
    • Starting from the top edge, lift the display slightly.
    • If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
    • Before completely removing the display:
    • Disconnect the three display cables.
    • Gently peel from the frame 2 orange ribbon cables that are glued to it, as those should stay with the display. (e.g. use a thin plastic card to separate them)
  4. Microsoft Surface Pro Display Replacement, Removal: 4 단계, 이미지 1개 중 1개
    • Remove the display.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Adam O'Camb
회원 가입일: 04/11/15
217,580 평판
안내서 416개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 101
전체 시간: 11,104
