주요 콘텐츠로 건너뛰기
Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement
필요한 것
  1. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement, Thumbstick Covers: 1 단계, 이미지 3개 중 1개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement, Thumbstick Covers: 1 단계, 이미지 3개 중 2개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement, Thumbstick Covers: 1 단계, 이미지 3개 중 3개
    • Remove the battery pack cover.
    • If there are any batteries inside of it, remove them.
  2. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 2 단계, 이미지 3개 중 1개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 2 단계, 이미지 3개 중 2개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 2 단계, 이미지 3개 중 3개
    • Place an iFixit opening tool between the seam of both the front and side plates.
    • Move the tool repeatedly along the seam between the two plates until the side plate is wholly disconnected from the front plate.
  3. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 3 단계, 이미지 3개 중 1개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 3 단계, 이미지 3개 중 2개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 3 단계, 이미지 3개 중 3개
    • Remove or pick a hole on the warranty sticker label to reveal the center screw.
    • Remove all five screws from the backplate using a TR8 Torx screwdriver.
  4. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 4 단계, 이미지 3개 중 1개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 4 단계, 이미지 3개 중 2개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the front plate from the controller.
  5. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 5 단계, 이미지 3개 중 1개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 5 단계, 이미지 3개 중 2개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 5 단계, 이미지 3개 중 3개
    • Pop-out the old thumbsticks and connect the new thumbsticks to the joystick.
결론
다른 18명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Edgar Galindo
회원 가입일: 03/20/22
558 평판
안내서 1개를 작성함
CSU Los Angeles, Team 8-80, Briggs Spring 2022 CSU Los Angeles, Team 8-80, Briggs Spring 2022 회원
CSULA-BRIGGS-S22S8G80
1 회원
안내서 4개를 작성함
4가이드 댓글
Does this method fix joystick drift?
Aaron - 답글
@aaron73239 , to fix the joystick drift, you might want to try this guide.
Kris Rodriguez -
Where is the article addressing stick-drift/replacement, if this is not it?
Pictory - 답글
Perhaps it is this article? Xbox One Wireless Controller Model 1708 Button Replacement
Would be appreciated if someone with relevant knowledge or experience would confirm this.
Pictory -
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 63
지난 30일: 269
전체 시간: 29,272
