이 안내서에는 최근 변경 사항이 있습니다. 최신 확인되지 않은 버전 으로 전환하세요.
소개
Faulty battery or logic board? Replace them!
필요한 것
Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
Use a Zune opening tool to pry the digitizer ribbon cable connector up off the logic board.
Use a Zune opening tool to push the small plastic clip securing the logic board near its lower left edge toward the headphone jack while gently lifting the upper edge of the logic board.
Use a Zune opening tool to pull the plastic clip away from the logic board while gently pulling the board away from the bottom edge of the Zune.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 3개
thanks, dude, that was really helpful
Last step is missing to show how to disconnect the battery from the board.. is it soldered ?
Yeah it is soldered.
