주요 콘텐츠로 건너뛰기
Mid F900 Motherboard Replacement
필요한 것
  1. Mid F900 Motherboard Replacement, Back Cover: 1 단계, 이미지 1/1
    • Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
    • Screws are 5mm x 1mm in size.
  2. Mid F900 Motherboard Replacement: 2 단계, 이미지 1/2 Mid F900 Motherboard Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to pry off the white back-plate of the device.
  3. Mid F900 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/2 Mid F900 Motherboard Replacement, Motherboard: 3 단계, 이미지 2/2
    • Using a +00 Phillips head screwdriver, remove the screws securing the motherboard to the device housing.
    • Screws are 4mm x 1mm in size.
  4. Mid F900 Motherboard Replacement: 4 단계, 이미지 1/2 Mid F900 Motherboard Replacement: 4 단계, 이미지 2/2
    • Desolder the two black and red wires connected to the motherboard.
    • Unclip and remove the ribbon cables attached to the motherboard.
    • For soldering help, use the How to Solder and Desolder Connections guide.
  5. Mid F900 Motherboard Replacement: 5 단계, 이미지 1/2 Mid F900 Motherboard Replacement: 5 단계, 이미지 2/2
    • Carefully lift and remove the motherboard from the device housing.
결론
Matthew Oliva
회원 가입일: 09/10/16
364 평판
안내서 3개 작성하였습니다
USF Tampa, Team 6-6, Remmell Fall 2016 USF Tampa, Team 6-6, Remmell Fall 2016 회원
USFT-REMMELL-F16S6G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 325
