주요 콘텐츠로 건너뛰기
Milwaukee Hackzall 2625-20 Motor Replacement
필요한 것
  1. Milwaukee Hackzall 2625-20 Motor Replacement, Outer Casing: 1 단계, 이미지 1/2 Milwaukee Hackzall 2625-20 Motor Replacement, Outer Casing: 1 단계, 이미지 2/2
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Motor Replacement, Electric Motor: 2 단계, 이미지 1/1
    • Find the red and black wire running from the back of the motor to the trigger mechanism.
    • With a soldering iron remove the two solders on the trigger mechanism.
  3. Milwaukee Hackzall 2625-20 Motor Replacement: 3 단계, 이미지 1/2 Milwaukee Hackzall 2625-20 Motor Replacement: 3 단계, 이미지 2/2
    • Remove the two screws connecting the motor to the gear box with a T15 torx screwdriver.
    • The motor is now free and can be removed from the tool.
결론
Mason Jones
회원 가입일: 09/18/19
572 평판
안내서 5개 작성하였습니다
댓글 2개
Is there any chance to change only brushes in this motor?
Marcin Kędzior - 답글
That’s my exact question as well, nobody seems to cover this..
Anthony DeSanto - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 39
전체 시간: 2,301
