주요 콘텐츠로 건너뛰기
Milwaukee Hackzall 2625-20 Trigger Replacement
필요한 것
  1. Milwaukee Hackzall 2625-20 Trigger Replacement, Trigger: 1 단계, 이미지 1/2 Milwaukee Hackzall 2625-20 Trigger Replacement, Trigger: 1 단계, 이미지 2/2
    • Use a T9 Torx screwdriver to remove the one 7.0 mm screw.
    • Use a T10 Torx screwdriver to remove the one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight 16.0 mm screws.
    • Remove the casing to reveal the internal components.
  2. Milwaukee Hackzall 2625-20 Trigger Replacement: 2 단계, 이미지 1/1
    • Use a soldering iron to desolder the connections on the back of the trigger assembly.
    • Practice caution while soldering. Ensure proper safety and soldering procedure is followed to avoid component damage and injury.
    • For more information on soldering, check out this guide.
  3. Milwaukee Hackzall 2625-20 Trigger Replacement: 3 단계, 이미지 1/2 Milwaukee Hackzall 2625-20 Trigger Replacement: 3 단계, 이미지 2/2
    • Remove the rest of the trigger assembly from the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mason Jones
회원 가입일: 09/18/19
572 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 33
전체 시간: 1,690
