주요 콘텐츠로 건너뛰기
Milwaukee Hex Impact Driver 2753-20 Trigger Replacement
필요한 것
  1. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Battery: 1 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Battery: 1 단계, 이미지 2/2
    • While pinching the red locking buttons, pull the battery away from the front of the drill until the battery is fully removed.
    • The battery is missing from this device so its removal is being mimed.
  2. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Milwaukee Hex Impact Driver 2753-20 Cover Removal: 2 단계, 이미지 1/1
    • Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
    • Remove the two 40 mm Torx T10 screws near the bottom of the cover.
  3. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement: 3 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2753-20 Trigger Replacement: 3 단계, 이미지 2/2
    • Carefully remove the cover.
    • If there is buildup from sawdust or sediment it might be a little difficult to take apart.
  4. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Trigger: 4 단계, 이미지 1/2 Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Trigger: 4 단계, 이미지 2/2
    • Lift the trigger assembly from the device. It is connected to the circuit board by wires.
    • Carefully desolder the wires off of the trigger assembly using a soldering iron on medium heat.
    • Refer to this guide for proper desoldering technique.
  5. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement: 5 단계, 이미지 1/1
    • Remove the trigger assembly from the device.
    • Replace old trigger assembly with replacement part no. 14-20-0013.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Larson
회원 가입일: 01/16/19
243 평판
안내서 2개 작성하였습니다
University of Alabama, Team S2-G3, Bedsole Spring 2019 University of Alabama, Team S2-G3, Bedsole Spring 2019 회원
UA-BEDSOLE-S19S2G3
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 44
전체 시간: 4,528
