주요 콘텐츠로 건너뛰기
Milwaukee M18 2606-20 Circuit Board Replacement
필요한 것
  1. Milwaukee M18 2606-20 Circuit Board Replacement, Circuit Board: 1 단계, 이미지 1/2 Milwaukee M18 2606-20 Circuit Board Replacement, Circuit Board: 1 단계, 이미지 2/2
    • Remove the seven 18 mm screws, using the T3 Torx Screwdriver, from the handle area of the case.
    • Remove the two 21 mm screws, using the T3 Torx Screwdriver, from the top of the case.
  2. Milwaukee M18 2606-20 Circuit Board Replacement: 2 단계, 이미지 1/3 Milwaukee M18 2606-20 Circuit Board Replacement: 2 단계, 이미지 2/3 Milwaukee M18 2606-20 Circuit Board Replacement: 2 단계, 이미지 3/3
    • Remove the four 20 mm screws, using the T3 Torx Screwdriver, from the front of the case.
  3. Milwaukee M18 2606-20 Circuit Board Replacement: 3 단계, 이미지 1/2 Milwaukee M18 2606-20 Circuit Board Replacement: 3 단계, 이미지 2/2
    • Peel back the sticker at the bottom of the drill handle.
  4. Milwaukee M18 2606-20 Circuit Board Replacement: 4 단계, 이미지 1/2 Milwaukee M18 2606-20 Circuit Board Replacement: 4 단계, 이미지 2/2
    • Open the case by sliding the opening tool all the way around the case to pry it apart.
  5. Milwaukee M18 2606-20 Circuit Board Replacement: 5 단계, 이미지 1/3 Milwaukee M18 2606-20 Circuit Board Replacement: 5 단계, 이미지 2/3 Milwaukee M18 2606-20 Circuit Board Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the 4-pin and 5-pin connector, using the tweezers, from the circuit board.
  6. Milwaukee M18 2606-20 Circuit Board Replacement: 6 단계, 이미지 1/3 Milwaukee M18 2606-20 Circuit Board Replacement: 6 단계, 이미지 2/3 Milwaukee M18 2606-20 Circuit Board Replacement: 6 단계, 이미지 3/3
    • Desolder all of the wires connected to the circuit board.
    • When you take the circuitboard out of the case, watch for a spring that is in the back of the battery contacts as it can fly out.
결론
Markus Eldridge
회원 가입일: 09/24/19
874 평판
안내서 5개 작성하였습니다
댓글 한 개
Replacement M18 Battery for Milwaukee Power Tool 2606-20
Type: Li-ion
Volt: 18V
Capacity: 5000mAh
Color: Black
Weight: 932g
Dimension: 141.15 x 78.00 x 73.95mm
Milwaukee 2606-20 Power Tool Batteries are made from the highest quality parts and are compatible with the Milwaukee cordless tools. And, this Milwaukee 2606-20 battery can be charged with original battery charger. Go to view more about this battery on https://www.drill-batteries.com/batteryp...
Drillbatterycomau - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 31
30일 전: 193
전체 시간: 8,826
