주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Momentary Switch Replacement
필요한 것
  1. Momentary Switch Replacement, Turn off power: 1 단계, 이미지 3개 중 1개 Momentary Switch Replacement, Turn off power: 1 단계, 이미지 3개 중 2개 Momentary Switch Replacement, Turn off power: 1 단계, 이미지 3개 중 3개
    • Find your Breaker Panel.
    • Identify the breaker to turn off.
    • There'll typically be a table listing the rooms corresponding to breakers.
    • Turn off the breaker.
    • Press the switch to ensure that the power is actually off (p. ex. the lights don't turn on).
  2. Momentary Switch Replacement, Remove the old switch cover: 3 단계, 이미지 3개 중 1개 Momentary Switch Replacement, Remove the old switch cover: 3 단계, 이미지 3개 중 2개 Momentary Switch Replacement, Remove the old switch cover: 3 단계, 이미지 3개 중 3개
    • Remove the switch cover by jamming a flat head screwdriver into the gap between the outer frame and the switch cover.
    • Some manufacturers, like Busch-Jaeger have an extra frame beneath the switch cover, so you'll have to remove that as well.
    • Remove the frame
    • If you can't remove the frame because there's a wall socket on the same frame, take a look at this guide, on how to remove the cover of a wall outlet.
  3. Momentary Switch Replacement, Remove the old switch: 4 단계, 이미지 1개 중 1개
    • Loosen the holding claws by turning the two screws.
    • If your switch is mounted inside a cavity wall box you can remove it by loosening the two screws around the perimeter and turning the switch until the two keyholes line up.
  4. Momentary Switch Replacement, Determine voltage absence: 5 단계, 이미지 2개 중 1개 Momentary Switch Replacement, Determine voltage absence: 5 단계, 이미지 2개 중 2개
    • Use a Duspol or any other two-pole voltage tester to test if there is voltage at the contacts.
    • Do not work on live circuits if you are not an experienced professional.
  5. Momentary Switch Replacement, Disconnect the wires: 6 단계, 이미지 1개 중 1개
    • Disconnect the wires form the old switch.
    • If the old switch has Push-In contacts, you can unlock the terminals by pushing down on the plastic levers.
    • If you short Earth to Neutral you'll trigger your GFCI/RCD, even if the power is off.
  6. Momentary Switch Replacement, Connect the new switch: 7 단계, 이미지 1개 중 1개
    • Connect the new switch. The new switch will typically mark where to connect which wire.
    • In (Phase Conductor/L)
    • Out
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sebastian
회원 가입일: 08/19/18
33,106 평판
안내서 72개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 31
지난 30일: 140
전체 시간: 2,782
