주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wall Outlet (Type F) Replacement
필요한 것
  1. Wall Outlet (Type F) Replacement, Turn off power: 1 단계, 이미지 3개 중 1개 Wall Outlet (Type F) Replacement, Turn off power: 1 단계, 이미지 3개 중 2개 Wall Outlet (Type F) Replacement, Turn off power: 1 단계, 이미지 3개 중 3개
    • Find your Breaker Panel.
    • Identify the breaker to turn off.
    • There'll typically be a table listing the circuits corresponding to breakers.
    • Turn off the breaker.
  2. Wall Outlet (Type F) Replacement, Determine voltage absence: 2 단계, 이미지 1개 중 1개
    • Use a Duspol or any other two-pole voltage tester to test if there is voltage at the contacts.
    • Do not work on live circuits if you are not an experienced professional.
  3. Wall Outlet (Type F) Replacement, Remove the old outlet cover: 3 단계, 이미지 3개 중 1개 Wall Outlet (Type F) Replacement, Remove the old outlet cover: 3 단계, 이미지 3개 중 2개 Wall Outlet (Type F) Replacement, Remove the old outlet cover: 3 단계, 이미지 3개 중 3개
    • Remove the outlet cover by unscrewing the middle captive screw with flat head screwdriver.
    • Remove the frame.
    • If you can't remove the frame because there's a switch on the same frame, take a look at this guide, on how to remove the cover of a switch.
  4. Wall Outlet (Type F) Replacement, Remove the wall outlet: 4 단계, 이미지 1개 중 1개
    • Loosen the holding claws by turning the two screws.
    • If your outlet is mounted inside a cavity wall box you can remove it by loosening the two screws around the perimeter and turning the switch until the two keyholes line up.
  5. Wall Outlet (Type F) Replacement, Disconnect the wires: 5 단계, 이미지 1개 중 1개
    • Disconnect the wires form the old outlet.
    • If the old outlet has Push-In contacts, you can unlock the terminals by pushing down on the clear plastic levers.
    • If you short Earth to Neutral you'll trigger your GFCI/RCD even if the power is off.
    • Connect the wires to the new outlet.
    • There is no rule on where to connect the Phase Conductor, but it's usually considered best practice to connect it on the right side, as it makes it easier for electricians to test the outlet with a Duspol.
  6. Wall Outlet (Type F) Replacement, Mount the outlet: 7 단계, 이미지 3개 중 1개 Wall Outlet (Type F) Replacement, Mount the outlet: 7 단계, 이미지 3개 중 2개 Wall Outlet (Type F) Replacement, Mount the outlet: 7 단계, 이미지 3개 중 3개
    • Mount the outlet by following the previous steps in reverse.
  7. Wall Outlet (Type F) Replacement, Turn the power back on: 8 단계, 이미지 1개 중 1개
    • Turn the power back on.
  8. Wall Outlet (Type F) Replacement, Test the new outlet: 9 단계, 이미지 3개 중 1개 Wall Outlet (Type F) Replacement, Test the new outlet: 9 단계, 이미지 3개 중 2개 Wall Outlet (Type F) Replacement, Test the new outlet: 9 단계, 이미지 3개 중 3개
    • Measure across Hot and Neutral.
    • You want 230V
    • Measure across Hot and Ground.
    • You want 230V
    • Measure across Ground and Neutral.
    • You want 0V
    • Apply load between Hot and Neutral by pressing the two large buttons.
    • If this trips your GFCI, you either swapped Ground and Neutral, or your Neutral belongs to a different GFCI than your Phase Conductor.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sebastian
회원 가입일: 08/19/18
33,106 평판
안내서 72개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 52
지난 30일: 351
전체 시간: 4,572
