주요 콘텐츠로 건너뛰기
Motherboard Replacement
필요한 것
  1. Motherboard Replacement, Bottom Cover: 1 단계, 이미지 1/2 Motherboard Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Motherboard Replacement: 3 단계, 이미지 1/2 Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Motherboard Replacement, Motherboard Cover: 4 단계, 이미지 1/3 Motherboard Replacement, Motherboard Cover: 4 단계, 이미지 2/3 Motherboard Replacement, Motherboard Cover: 4 단계, 이미지 3/3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Motherboard Replacement, Battery: 5 단계, 이미지 1/2 Motherboard Replacement, Battery: 5 단계, 이미지 2/2
    • Remove the battery from the holder. It may be difficult the first time.
    • Use a spudger between the battery and speaker wall to loosen it from its surroundings.
    • If the battery is punctured, leaking, or bloated/puffy, it may be hazardous and should be properly disposed of.
  6. Motherboard Replacement: 6 단계, 이미지 1/2 Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove the pressure-fitted foam from the slot by hand.
    • Unravel and remove foam from the wires.
    • When reassembling, the foam can be re-wrapped if care is taken when handling it.
  7. Motherboard Replacement: 7 단계, 이미지 1/1
    • Using a soldering iron, remove the leads, separating the battery from motherboard.
    • Follow this guide to help you remove the wires from the motherboard if you are unfamiliar with soldering.
  8. Motherboard Replacement, Speakers: 8 단계, 이미지 1/2 Motherboard Replacement, Speakers: 8 단계, 이미지 2/2
    • Remove the three screws that are holding the speaker down.
    • Be careful not to rip out the speaker while taking out the screws.
  9. Motherboard Replacement: 9 단계, 이미지 1/2 Motherboard Replacement: 9 단계, 이미지 2/2
    • Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
  10. Motherboard Replacement: 10 단계, 이미지 1/2 Motherboard Replacement: 10 단계, 이미지 2/2
    • Remove the speaker from the motherboard.
    • Remove the speaker ring.
    • Be careful not to remove other components in the speaker.
    • Repeat Steps 5-7 with the other speaker.
  11. Motherboard Replacement, Motherboard: 11 단계, 이미지 1/2 Motherboard Replacement, Motherboard: 11 단계, 이미지 2/2
    • Remove these two 4.5 mm Philips silver screws holding down the motherboard.
    • The motherboard should be able to be lifted right out of the housing.
  12. Motherboard Replacement: 12 단계, 이미지 1/3 Motherboard Replacement: 12 단계, 이미지 2/3 Motherboard Replacement: 12 단계, 이미지 3/3
    • You will finds a ribbon cable connecting the motherboard to the control interface circuit board.
    • Using a spudger or plastic opening tool, lift flap on the ribbon cable ZIF connector.
    • Using a plastic pry tool or fine tip plastic tool to open the clamp.
    • Using the tool, try lifting the clamp up on either location, noted by the blue arrow.
    • The ribbon should pop out, if not you should be able to slide it out from the clamp.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Samuel Knapik
회원 가입일: 03/04/16
121 평판
안내서 1개 작성함
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 UMass Dartmouth, Team 3-2, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S3G2
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 9
전체 시간: 354
