주요 콘텐츠로 건너뛰기
Motherboard Replacement
필요한 것
  1. Motherboard Replacement, Back Cover: 1 단계, 이미지 1/3 Motherboard Replacement, Back Cover: 1 단계, 이미지 2/3 Motherboard Replacement, Back Cover: 1 단계, 이미지 3/3
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Motherboard Replacement: 2 단계, 이미지 1/1
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Motherboard Replacement, Battery: 3 단계, 이미지 1/1
    • Remove masking tape from the battery.
  4. Motherboard Replacement: 4 단계, 이미지 1/3 Motherboard Replacement: 4 단계, 이미지 2/3 Motherboard Replacement: 4 단계, 이미지 3/3
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. Motherboard Replacement: 5 단계, 이미지 1/3 Motherboard Replacement: 5 단계, 이미지 2/3 Motherboard Replacement: 5 단계, 이미지 3/3
    • De-solder the three contact points and remove the battery.
    • See the following guide for instructions on how to solder. How To Solder and Desolder Connections
    • Use caution when operating the soldering iron.
  6. Motherboard Replacement, Motherboard: 6 단계, 이미지 1/3 Motherboard Replacement, Motherboard: 6 단계, 이미지 2/3 Motherboard Replacement, Motherboard: 6 단계, 이미지 3/3
    • Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
    • Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
  7. Motherboard Replacement: 7 단계, 이미지 1/1
    • Use the nut driver and J00 bit to remove the three 4 mm screws.
  8. Motherboard Replacement: 8 단계, 이미지 1/3 Motherboard Replacement: 8 단계, 이미지 2/3 Motherboard Replacement: 8 단계, 이미지 3/3
    • Peel back metal tape that is hiding the auxiliary port wires.
    • Remove tape that is holding the speaker wires in place.
    • Lift up on the motherboard to release it from the tablet.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Connor Fisher
회원 가입일: 11/04/16
212 평판
안내서 1개 작성함
Baylor, Team 4-1, Williams Fall 2016 Baylor, Team 4-1, Williams Fall 2016 회원
BU-WILLIAMS-F16S4G1
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 271
