주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Moto Z Fingerprint Sensor Replacement
필요한 것
  1. Moto Z Fingerprint Sensor Replacement, Display Assembly: 1 단계, 이미지 1/1
    • Heat an iOpener and apply it to the left edge of the phone for at least 90 seconds.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
    • As you're waiting for the adhesive to soften, move on and read the following step to get an idea of where to pry.
  2. Moto Z Fingerprint Sensor Replacement: 2 단계, 이미지 1/2 Moto Z Fingerprint Sensor Replacement: 2 단계, 이미지 2/2
    • In the following steps you will be cutting through the adhesive around the edge of the display assembly.
    • To avoid damage, do not cut in the following areas:
    • The OLED panel
    • The home button
    • The flash unit
  3. Moto Z Fingerprint Sensor Replacement: 3 단계, 이미지 1/3 Moto Z Fingerprint Sensor Replacement: 3 단계, 이미지 2/3 Moto Z Fingerprint Sensor Replacement: 3 단계, 이미지 3/3
    • Apply a suction cup as close to the heated edge as possible.
    • Lift on the suction cup and insert the tip of an opening pick into the gap.
    • Do not insert the pick more than 1/16" (1.5 mm). Over-inserting the pick may damage the OLED panel.
  4. Moto Z Fingerprint Sensor Replacement: 4 단계, 이미지 1/3 Moto Z Fingerprint Sensor Replacement: 4 단계, 이미지 2/3 Moto Z Fingerprint Sensor Replacement: 4 단계, 이미지 3/3
    • Carefully slide the tip of the opening pick down and up the side of the phone, making sure not to cut deeper than 1/16" (1.5 mm).
    • As you run the pick along the side, you will feel the tip of the pick press against the edge of the OLED panel. That is as far as the pick should go without damaging the panel.
    • Once you have separated the adhesive, leave an opening pick in the side to keep the adhesive from resealing.
  5. Moto Z Fingerprint Sensor Replacement: 5 단계, 이미지 1/1
    • Repeat the heating, lifting, and cutting steps for the remaining long edge of the phone.
  6. Moto Z Fingerprint Sensor Replacement: 6 단계, 이미지 1/1
  7. Moto Z Fingerprint Sensor Replacement: 7 단계, 이미지 1/2 Moto Z Fingerprint Sensor Replacement: 7 단계, 이미지 2/2
    • Insert an opening pick into the flash side corner of the phone and carefully slice around the flash unit.
    • Do not insert the pick more than 1/16" (1.5 mm) into the edge.
    • Once you are done cutting, leave the pick in the corner to prevent the adhesive from resealing.
  8. Moto Z Fingerprint Sensor Replacement: 8 단계, 이미지 1/3 Moto Z Fingerprint Sensor Replacement: 8 단계, 이미지 2/3 Moto Z Fingerprint Sensor Replacement: 8 단계, 이미지 3/3
    • Insert an opening pick into the remaining top corner of the phone.
    • Carefully slice through the adhesive across the top of the phone.
    • Do not insert the pick beyond 1/2" (12.5 mm).
  9. Moto Z Fingerprint Sensor Replacement: 9 단계, 이미지 1/1
    • Apply a heated iOpener to the bottom edge of the phone for at least 90 seconds.
  10. Moto Z Fingerprint Sensor Replacement: 10 단계, 이미지 1/3 Moto Z Fingerprint Sensor Replacement: 10 단계, 이미지 2/3 Moto Z Fingerprint Sensor Replacement: 10 단계, 이미지 3/3
    • Insert an opening pick into a bottom corner and slice towards the home button, stopping before you reach it.
    • Once you're done with the corner, leave a pick in place to prevent the adhesive from sealing.
    • Repeat the process for the other bottom corner.
  11. Moto Z Fingerprint Sensor Replacement: 11 단계, 이미지 1/2 Moto Z Fingerprint Sensor Replacement: 11 단계, 이미지 2/2
    • Carefully twist the first opening pick slightly to help release the edge adhesive.
    • Repeat the same process for each remaining pick, moving them as necessary and twisting slightly to release the adhesive.
  12. Moto Z Fingerprint Sensor Replacement: 12 단계, 이미지 1/3 Moto Z Fingerprint Sensor Replacement: 12 단계, 이미지 2/3 Moto Z Fingerprint Sensor Replacement: 12 단계, 이미지 3/3
    • Lift the earpiece end of the display up to provide access to the display cables.
    • Do not open the display beyond 90 degrees, and always support the display panel.
  13. Moto Z Fingerprint Sensor Replacement: 13 단계, 이미지 1/3 Moto Z Fingerprint Sensor Replacement: 13 단계, 이미지 2/3 Moto Z Fingerprint Sensor Replacement: 13 단계, 이미지 3/3
    • Use the point of a spudger to pry the display cable shield up.
    • Remove the display cable shield.
  14. Moto Z Fingerprint Sensor Replacement: 14 단계, 이미지 1/2 Moto Z Fingerprint Sensor Replacement: 14 단계, 이미지 2/2
    • Use the point of the spudger to lift and disconnect the display cable connector from its socket.
  15. Moto Z Fingerprint Sensor Replacement: 15 단계, 이미지 1/2 Moto Z Fingerprint Sensor Replacement: 15 단계, 이미지 2/2
    • Remove the display assembly.
    • Compare your new replacement part to the original part. You may need to transfer remaining components (such as the flash lens) or remove adhesive backings from the new part before installing.
    • Before you reinstall the display assembly, thoroughly remove any remaining adhesive and glass from the frame.
    • After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Use the Motorola Moto Z display adhesive to reseal your phone. Follow this guide for instructions on how to apply adhesive to the replacement screen.
  16. Moto Z Fingerprint Sensor Replacement, Fingerprint Sensor: 16 단계, 이미지 1/2 Moto Z Fingerprint Sensor Replacement, Fingerprint Sensor: 16 단계, 이미지 2/2
    • Use tweezers to peel off any tape on the home button connector and home button
  17. Moto Z Fingerprint Sensor Replacement: 17 단계, 이미지 1/2 Moto Z Fingerprint Sensor Replacement: 17 단계, 이미지 2/2
    • Use the point of a spudger to flip up the home button connector's lock.
  18. Moto Z Fingerprint Sensor Replacement: 18 단계, 이미지 1/2 Moto Z Fingerprint Sensor Replacement: 18 단계, 이미지 2/2
    • Use tweezers to carefully pull the home button cable straight out of the socket.
  19. Moto Z Fingerprint Sensor Replacement: 19 단계, 이미지 1/1
    • Remove the home button.
결론
Repair didn’t go as planned? Check out our Motorola Moto Z Answers community for troubleshooting help.
다른 한 분이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
252,842 평판
안내서 526개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 8
전체 시간: 1,540
