주요 콘텐츠로 건너뛰기
Motorola Droid Mini Front screen Replacement
필요한 것
  1. Motorola Droid Mini Front screen Replacement, Back Case: 1 단계, 이미지 1/2 Motorola Droid Mini Front screen Replacement, Back Case: 1 단계, 이미지 2/2
    • Pull out the volume keys using the iFixit opening tool.
  2. Motorola Droid Mini Front screen Replacement: 2 단계, 이미지 1/2 Motorola Droid Mini Front screen Replacement: 2 단계, 이미지 2/2
    • Pry off the back case gently using the iFixit opening tool.
    • Make sure to go around the entire perimeter of the case.
  3. Motorola Droid Mini Front screen Replacement, Front screen: 3 단계, 이미지 1/2 Motorola Droid Mini Front screen Replacement, Front screen: 3 단계, 이미지 2/2
    • Use the T5 screw head to unscrew the 9 silver screws from the housing frame. Carefully separate the housing frame from the motherboard.
  4. Motorola Droid Mini Front screen Replacement: 4 단계, 이미지 1/3 Motorola Droid Mini Front screen Replacement: 4 단계, 이미지 2/3 Motorola Droid Mini Front screen Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Carefully use the tweezers to separate the motherboard from the screen.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Alec Fales
회원 가입일: 10/08/14
337 평판
안내서 2개 작성하였습니다
USF Tampa, Team 9-2, Leahy Fall 2014 USF Tampa, Team 9-2, Leahy Fall 2014 회원
USFT-LEAHY-F14S9G2
3 회원들
안내서 5개 작성하였습니다
댓글 4개
This guide is inaccurate in essentially every step.
A few examples:
1) there are 13 screws to remove the back housing
2) an additional 2 screws to remove the motherboard
3) fails to mention transferring power button and ear speaker
robertanthonycastillo - 답글
Just replaced a cracked screen on this model. This guide is pretty misleading. In addition to all the the things missing that the last commenter mentioned, it entirely fails to detail the most crucial part: replacing the screen. For which task you need a heat gun (hair dryer will do), metal spudger, replacement screen, and 1mm adhesive tape. I recommend this video to get a sense of what is actually involved: https://youtu.be/Q2tlwlHpZ04
Nate Rawson - 답글
Horrible guide. Change the title to "how to partially remove screen"
Lee - 답글
I used the guide below to replace/re-attach the LCD and digitizer into the front frame. Sat the phone face down on a paper towel with books on it, while on a 3d printer bed heated to 80 degrees C, for total of about 20 minutes (IR thermometer measured screen/frame at around 65C). Will see how well this holds up…
iPhone 디스플레이 접착제 교체
rbol - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 6,204
