주요 콘텐츠로 건너뛰기
Motorola Droid Turbo 2 Rear Cover Adhesive Guide
필요한 것
  1. Motorola Droid Turbo 2 Rear Cover Adhesive Guide, Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 1 단계, 이미지 1/3 Motorola Droid Turbo 2 Rear Cover Adhesive Guide, Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 1 단계, 이미지 2/3 Motorola Droid Turbo 2 Rear Cover Adhesive Guide, Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 1 단계, 이미지 3/3
    • Prepare the phone frame surface by removing all traces of adhesive.
    • Use tweezers to pull adhesive chunks off. Use the opening tool to scrape residue off. You can use high concentration (over 90%) isopropyl alcohol to help dissolve residue.
    • Be careful not to damage the wireless charging coil when scraping around it.
    • If you are re-using the rear cover, prepare the inner surface by removing all traces of adhesive from it.
    • Do not attempt to remove the rectangular plastic liner near the bottom of the cover, but do scrape off all adhesive on it.
  2. Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 2 단계, 이미지 1/1
    • Use your finger and firmly press the metal rear camera plate from the outer side of the rear cover until you dislodge it from its recess.
    • Remove the rear camera plate.
    • Clean the perimeter of the rear camera plate and remove any adhesive residue.
  3. Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 3 단계, 이미지 1/2 Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 3 단계, 이미지 2/2
    • Set the pre-cut adhesive strip next to the rear cover so that it is properly oriented—the pull tabs should point to the bottom left corner of the cover.
    • Optionally, you can tape the pre-cut adhesive strip into position for easier application.
    • Lay the pre-cut adhesive strip over the rear cover, aligning it to the long edges.
    • Tape one long edge of the pre-cut adhesive strip to the rear cover, locking the alignment in place while allowing the strip to still swing.
  4. Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 4 단계, 이미지 1/2 Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 4 단계, 이미지 2/2
    • Peel and remove the clear plastic liner from the pre-cut adhesive strip.
    • This will expose adhesive facing the rear cover, so don't remove the liner until you are ready to begin placement.
  5. Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 5 단계, 이미지 1/3 Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 5 단계, 이미지 2/3 Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 5 단계, 이미지 3/3
    • The exposed adhesive is very sticky and prone to adhering to surfaces unintentionally. Be careful while handling and aligning the adhesive.
    • Align the adhesive strip to a long edge of the rear cover.
    • If you have previously taped the adhesive strip to the rear cover, the strip should already be aligned.
    • Beginning from the alignment edge, use your fingers to press the adhesive strip onto the rear cover.
  6. Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 6 단계, 이미지 1/2 Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 6 단계, 이미지 2/2
    • Pull and remove the blue liner tab located in the rear cover's rear camera hole.
    • This will expose a ring of adhesive around the hole, which will hold the rear camera plate in place.
  7. Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 7 단계, 이미지 1/3 Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 7 단계, 이미지 2/3 Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 7 단계, 이미지 3/3
    • Align the rear camera plate with the rear cover's camera hole and drop it in place.
    • Press the rear camera plate in place. You may need to squeeze from both sides to ensure that the adhesive bonds properly.
  8. Motorola Droid Turbo 2 Rear Cover Adhesive Guide: 8 단계, 이미지 1/1
    • Continue with phone re-assembly until you are ready to seal up the phone.
    • Be sure to test your phone's functionality before sealing your phone.
    • Peel and remove the blue liner from the rear cover, exposing the adhesive to stick onto the phone frame.
    • Align and press the rear cover onto the phone frame.
결론
Repair didn’t go as planned? Check out our Motorola Droid Turbo 2 Answers community for troubleshooting help.
다른 8명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
216,583 평판
안내서 441개 작성하였습니다
iFixit iFixit 회원
Community
139 회원들
안내서 16,888개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 8
전체 시간: 1,337
