주요 콘텐츠로 건너뛰기
Motorola Edge (2022) Back Cover Replacement
필요한 것
  1. Motorola Edge (2022) Back Cover Replacement, Heat the right edge: 1 단계, 이미지 1개 중 1개
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Edge (2022) Back Cover Replacement, Separate the right adhesive: 2 단계, 이미지 3개 중 1개 Motorola Edge (2022) Back Cover Replacement, Separate the right adhesive: 2 단계, 이미지 3개 중 2개 Motorola Edge (2022) Back Cover Replacement, Separate the right adhesive: 2 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back of the phone, as close to the middle of the right edge as possible.
    • Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  3. Motorola Edge (2022) Back Cover Replacement, Slice the right adhesive: 3 단계, 이미지 2개 중 1개 Motorola Edge (2022) Back Cover Replacement, Slice the right adhesive: 3 단계, 이미지 2개 중 2개
    • Slide the pick along the right edge to slice the adhesive.
    • Leave the pick in the bottom right edge to prevent the adhesive from resealing.
  4. Motorola Edge (2022) Back Cover Replacement, Heat the bottom edge: 4 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the back cover's bottom edge for two minutes.
  5. Motorola Edge (2022) Back Cover Replacement, Slice the bottom right corner adhesive: 5 단계, 이미지 2개 중 1개 Motorola Edge (2022) Back Cover Replacement, Slice the bottom right corner adhesive: 5 단계, 이미지 2개 중 2개
    • Rotate the pick around the bottom right corner to slice the adhesive.
  6. Motorola Edge (2022) Back Cover Replacement: 6 단계, 이미지 2개 중 1개 Motorola Edge (2022) Back Cover Replacement: 6 단계, 이미지 2개 중 2개
    • Slide the pick along the bottom edge to slice the adhesive.
    • Leave the pick in the bottom left edge to prevent the adhesive from resealing.
  7. Motorola Edge (2022) Back Cover Replacement: 7 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the back cover's left edge for two minutes.
  8. Motorola Edge (2022) Back Cover Replacement: 8 단계, 이미지 2개 중 1개 Motorola Edge (2022) Back Cover Replacement: 8 단계, 이미지 2개 중 2개
    • Rotate the pick around the bottom left corner to slice the adhesive.
  9. Motorola Edge (2022) Back Cover Replacement: 9 단계, 이미지 2개 중 1개 Motorola Edge (2022) Back Cover Replacement: 9 단계, 이미지 2개 중 2개
    • Slide the pick along the edge to slice the adhesive.
    • Leave the pick in the top left edge to prevent the adhesive from resealing.
  10. Motorola Edge (2022) Back Cover Replacement: 10 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the back cover's top edge for two minutes.
  11. Motorola Edge (2022) Back Cover Replacement: 11 단계, 이미지 2개 중 1개 Motorola Edge (2022) Back Cover Replacement: 11 단계, 이미지 2개 중 2개
    • Rotate the pick around the top left corner to slice the adhesive.
  12. Motorola Edge (2022) Back Cover Replacement: 12 단계, 이미지 2개 중 1개 Motorola Edge (2022) Back Cover Replacement: 12 단계, 이미지 2개 중 2개
    • Slide the pick along the top edge to slice the adhesive.
  13. Motorola Edge (2022) Back Cover Replacement, Remove the back cover: 13 단계, 이미지 2개 중 1개 Motorola Edge (2022) Back Cover Replacement, Remove the back cover: 13 단계, 이미지 2개 중 2개
    • Lift the back cover from the phone and remove it.
    • If the back cover is still stuck to the midframe, slide an opening pick around the edges of the phone until the cover separates completely.
결론
To reassemble your device, follow the instructions in reverse order.
작성자
4다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
155,120 평판
안내서 1,033개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
1가이드 댓글
Where can I find the rear cover to replace it with? Mine is spiderwebbed.
bigrebone - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 42
전체 시간: 2,280
