주요 콘텐츠로 건너뛰기
Motorola Edge Motherboard Cover Replacement
필요한 것
  1. Motorola Edge Motherboard Cover Replacement, Heat the bottom edge: 1 단계, 이미지 1개 중 1개
    • Completely power off your phone before you begin.
    • Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone because the display and internal battery are both susceptible to heat damage.
  2. Motorola Edge Motherboard Cover Replacement, Separate the bottom adhesive: 2 단계, 이미지 3개 중 1개 Motorola Edge Motherboard Cover Replacement, Separate the bottom adhesive: 2 단계, 이미지 3개 중 2개 Motorola Edge Motherboard Cover Replacement, Separate the bottom adhesive: 2 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  3. Motorola Edge Motherboard Cover Replacement, Slice the bottom adhesive: 3 단계, 이미지 3개 중 1개 Motorola Edge Motherboard Cover Replacement, Slice the bottom adhesive: 3 단계, 이미지 3개 중 2개 Motorola Edge Motherboard Cover Replacement, Slice the bottom adhesive: 3 단계, 이미지 3개 중 3개
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  4. Motorola Edge Motherboard Cover Replacement, Heat the right edge: 4 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  5. Motorola Edge Motherboard Cover Replacement, Separate the corner adhesive: 5 단계, 이미지 3개 중 1개 Motorola Edge Motherboard Cover Replacement, Separate the corner adhesive: 5 단계, 이미지 3개 중 2개 Motorola Edge Motherboard Cover Replacement, Separate the corner adhesive: 5 단계, 이미지 3개 중 3개
    • Rotate the opening pick around the bottom-right corner of the phone.
  6. Motorola Edge Motherboard Cover Replacement, Separate the right adhesive: 6 단계, 이미지 3개 중 1개 Motorola Edge Motherboard Cover Replacement, Separate the right adhesive: 6 단계, 이미지 3개 중 2개 Motorola Edge Motherboard Cover Replacement, Separate the right adhesive: 6 단계, 이미지 3개 중 3개
    • Insert a new opening pick into the gap you just created.
    • Slide the pick along the right edge of the phone to separate the adhesive.
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
  7. Motorola Edge Motherboard Cover Replacement, Remove the back cover: 7 단계, 이미지 3개 중 1개 Motorola Edge Motherboard Cover Replacement, Remove the back cover: 7 단계, 이미지 3개 중 2개 Motorola Edge Motherboard Cover Replacement, Remove the back cover: 7 단계, 이미지 3개 중 3개
    • Remove the back cover, taking care not to damage the components inside the phone.
  8. Motorola Edge Motherboard Cover Replacement, Remove the motherboard's screws: 8 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
  9. Motorola Edge Motherboard Cover Replacement, Remove the motherboard cover: 9 단계, 이미지 3개 중 1개 Motorola Edge Motherboard Cover Replacement, Remove the motherboard cover: 9 단계, 이미지 3개 중 2개 Motorola Edge Motherboard Cover Replacement, Remove the motherboard cover: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
    • The motherboard cover also contains the phone's flash.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
작성자
4다른 기여자 명과 함께
Jennifer Berg
회원 가입일: 03/21/22
2,840 평판
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 11
전체 시간: 275
