주요 콘텐츠로 건너뛰기
Motorola Moto E 2nd Generation Battery Replacement
필요한 것
  1. Motorola Moto E 2nd Generation Battery Replacement, Display Assembly: 1 단계, 이미지 1/1
    • Turn off the device before beginning your repair.
    • Using a heat gun, carefully apply heat around the edges of the display to soften the glue. Heat should be applied to the point where the phone isn't too hot to touch, but close enough.
  2. Motorola Moto E 2nd Generation Battery Replacement: 2 단계, 이미지 1/3 Motorola Moto E 2nd Generation Battery Replacement: 2 단계, 이미지 2/3 Motorola Moto E 2nd Generation Battery Replacement: 2 단계, 이미지 3/3
    • Using the small plastic opening tool, pry and slide all the way around the phone while carefully lifting up on the display.
    • The screen is secured by two-sided tape located on the edge.
  3. Motorola Moto E 2nd Generation Battery Replacement: 3 단계, 이미지 1/3 Motorola Moto E 2nd Generation Battery Replacement: 3 단계, 이미지 2/3 Motorola Moto E 2nd Generation Battery Replacement: 3 단계, 이미지 3/3
    • Once display is fully unglued from the frame, carefully lift it up and locate the display connector.
    • Using the same small plastic tool, carefully remove the yellow tape off the connector.
    • Now carefully undo the black connector lock by lifting it up in the direction of the red arrow.
    • Do not pry on the gray part of the connector.
    • Lastly slide the display cable off the connector. It should easily slide off, if not make sure the black lock is fully unlatched.
  4. Motorola Moto E 2nd Generation Battery Replacement, Earpiece Speaker: 4 단계, 이미지 1/3 Motorola Moto E 2nd Generation Battery Replacement, Earpiece Speaker: 4 단계, 이미지 2/3 Motorola Moto E 2nd Generation Battery Replacement, Earpiece Speaker: 4 단계, 이미지 3/3
    • Now that the display is out, remove the aluminum shield off the motherboard.
    • Unscrew the single 4mm screw located on the top using a T4 Torx bit.
    • After screw is out, gently remove the aluminum shield off the motherboard.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
  5. Motorola Moto E 2nd Generation Battery Replacement: 5 단계, 이미지 1/2 Motorola Moto E 2nd Generation Battery Replacement: 5 단계, 이미지 2/2
    • Using the metal spudger tool, very carefully remove the speaker by first gently prying up on the right side and then the bottom.
    • The ear piece is held by double sided tape and clips to the motherboard so be very careful.
  6. Motorola Moto E 2nd Generation Battery Replacement, Motherboard: 6 단계, 이미지 1/1
    • Unscrew the remaining 16- 4mm screws using a T4 Torx bit.
    • Using a magnet board is recommended as the screws are small and can be easily misplaced.
  7. Motorola Moto E 2nd Generation Battery Replacement: 7 단계, 이미지 1/3 Motorola Moto E 2nd Generation Battery Replacement: 7 단계, 이미지 2/3 Motorola Moto E 2nd Generation Battery Replacement: 7 단계, 이미지 3/3
    • Next remove the plastic C-shaped black plastic frame.
    • Using the metal spudger tool, gently pull up the right corner as indicated and work your way around until it's off the motherboard.
  8. Motorola Moto E 2nd Generation Battery Replacement: 8 단계, 이미지 1/2 Motorola Moto E 2nd Generation Battery Replacement: 8 단계, 이미지 2/2
    • Gently lift up the battery cable connector, it should come out very easy.
  9. Motorola Moto E 2nd Generation Battery Replacement: 9 단계, 이미지 1/3 Motorola Moto E 2nd Generation Battery Replacement: 9 단계, 이미지 2/3 Motorola Moto E 2nd Generation Battery Replacement: 9 단계, 이미지 3/3
    • After the battery cable is disconnected from the motherboard, use the metal spudger tool and carefully insert it in the small opening by the speaker and pry the motherboard up enough to fit your finger in between the motherboard and the phone frame.
    • Now just pull the motherboard starting from the top to bottom off the phone case.
  10. Motorola Moto E 2nd Generation Battery Replacement, Battery: 10 단계, 이미지 1/3 Motorola Moto E 2nd Generation Battery Replacement, Battery: 10 단계, 이미지 2/3 Motorola Moto E 2nd Generation Battery Replacement, Battery: 10 단계, 이미지 3/3
    • Use a spudger to gently pry up the battery.
    • It's best to use a non-metal spudger whenever possible, as a metal spudger is much more likely to accidentally puncture/damage the battery.
    • The battery is stuck to the plastic case with double sided tape.
    • Obtain a new battery and place it into the plastic casing using double sided tape or whatever is provided with the new battery.
결론
다른 39명이 해당 안내서를 완성하였습니다.
Andre Romualdo
회원 가입일: 02/08/16
3,765 평판
안내서 5개 작성하였습니다
USF Tampa, Team 12-3, Eyestone Spring 2016 USF Tampa, Team 12-3, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S12G3
3 회원들
안내서 14개 작성하였습니다
댓글 9개
Has anyone tried to Dremel it open from the backside? It's a cheap phone and I'd almost rather possibly ruin it than spend 30+ minutes tearing it apart.
GRINGOX - 답글
My phone came with the display falling out and flopping around. Videos only say how to take it apart. How do I fasten the display back on?
Wha Dahel - 답글
My bettri chanj ani problam
Tapas Sarkar - 답글
my mobile auto shutdown currunt working
Vishal Ankushkar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 67
전체 시간: 43,923
