주요 콘텐츠로 건너뛰기
Motorola Moto E4 Plus Motherboard Replacement
필요한 것
  1. Motorola Moto E4 Plus Motherboard Replacement, Remove the back cover: 1 단계, 이미지 1/3 Motorola Moto E4 Plus Motherboard Replacement, Remove the back cover: 1 단계, 이미지 2/3 Motorola Moto E4 Plus Motherboard Replacement, Remove the back cover: 1 단계, 이미지 3/3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Motherboard Replacement: 2 단계, 이미지 1/2 Motorola Moto E4 Plus Motherboard Replacement: 2 단계, 이미지 2/2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Motherboard Replacement, Remove the midframe screws: 3 단계, 이미지 1/1
    • Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
  4. Motorola Moto E4 Plus Motherboard Replacement, Release the midframe clips: 4 단계, 이미지 1/2 Motorola Moto E4 Plus Motherboard Replacement, Release the midframe clips: 4 단계, 이미지 2/2
    • The plastic midframe is still held in place with clips.
    • Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
    • Twist the spudger to release the plastic clip.
    • Repeat the process for the clip near the top right corner of the phone.
  5. Motorola Moto E4 Plus Motherboard Replacement, Remove the midframe: 5 단계, 이미지 1/2 Motorola Moto E4 Plus Motherboard Replacement, Remove the midframe: 5 단계, 이미지 2/2
    • Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
    • Remove the plastic midframe.
    • To reattach the plastic midframe, line up the midframe to the phone and squeeze along the edges to engage the clips.
  6. Motorola Moto E4 Plus Motherboard Replacement, Disconnect the battery: 6 단계, 이미지 1/2 Motorola Moto E4 Plus Motherboard Replacement, Disconnect the battery: 6 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
  7. Motorola Moto E4 Plus Motherboard Replacement, Disconnect the display cable: 7 단계, 이미지 1/2 Motorola Moto E4 Plus Motherboard Replacement, Disconnect the display cable: 7 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the display cable from its motherboard socket, near the bottom left corner of the motherboard.
  8. Motorola Moto E4 Plus Motherboard Replacement, Disconnect the antenna cable: 8 단계, 이미지 1/2 Motorola Moto E4 Plus Motherboard Replacement, Disconnect the antenna cable: 8 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the antenna cable from its motherboard socket.
  9. Motorola Moto E4 Plus Motherboard Replacement, Disconnect the interconnect cable: 9 단계, 이미지 1/2 Motorola Moto E4 Plus Motherboard Replacement, Disconnect the interconnect cable: 9 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the interconnect cable from its motherboard socket.
  10. Motorola Moto E4 Plus Motherboard Replacement, Remove the motherboard screws: 10 단계, 이미지 1/1
    • Remove the two black 3.2 mm long T3 screws securing the motherboard.
  11. Motorola Moto E4 Plus Motherboard Replacement, Remove the motherboard: 11 단계, 이미지 1/2 Motorola Moto E4 Plus Motherboard Replacement, Remove the motherboard: 11 단계, 이미지 2/2
    • Grasp the motherboard by the top corners and lift it out of the phone.
    • Remove the motherboard.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto E4 Plus Answers community for help.
다른 3명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
254,811 평판
안내서 529개 작성하였습니다
iFixit iFixit 회원
Staff
137 회원들
안내서 17,457개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 29
전체 시간: 1,584
