이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use your fingernail to pry under the notch on the bottom of the phone and remove the back cover.
Evenly apply heat to the edges of the touchscreen to loosen the adhesive. Continue to Step 3 once the edge of the screen is warm to the touch.
As the adhesive loosens, pry up an edge of the screen with a plastic opening tool or an opening pick. A suction cup may also be useful here.
Use an opening pick to hold that edge in place and continue this process around the entire screen, applying more heat as necessary.
이 단계에 사용된 도구:Tesa 61395 Tape$5.99-
Use a plastic opening tool to flip up the lock on the display cable ZIF connector.
Pull the display cable from its socket on the motherboard.
Remove the ten 2.4 mm T4 screws from the sides of the motherboard.
Remove the four 4.5 mm T4 screws from the top and bottom of the motherboard.
If adhesive residue is holding the motherboard in place, use a Jimmy to cut the adhesive between the motherboard and the back of the phone.
Carefully lift the right edge of the motherboard from the phone.
Use a plastic opening tool to disconnect the battery wires from the motherboard.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 2개
My phone is broken inside, it’s not cracked but it did fall off the table i need it fixed
my moto g3 display light problem,this display have no light what can i do
